Old 06-08-2001, 06:13 AM   #1
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Question Proper K&N oiling! HELP ME PLEASE!
I just washed and oiled my K&N cone filter last night, it is still greasy to the touch. Did I over oil it or is this right. I have a 99 RS with the "sensitive" MAF, therefore I cannot over oil my filter. Its not dripping off it by any means, nor has it ever. Should I wipe the surface off a bit or what...I followed the directions on the box (I read them BEFORE I started too) and just want to make sure.
Last time I did this I had an ITG cone on my Jetta, wash, dry, spray goo on it and bolt it on......help!
STiShawn is offline   Reply With Quote
Old 06-08-2001, 06:48 AM   #2
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Exclamation
PLEASE!!!! I'm going to the KC meet this afternoon, I need to know what to do! Bolt it on go, or wipe it down and dry it off...
Old 06-08-2001, 06:52 AM   #3
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Lightbulb
Shawn,
I wouldn't wipe it down. If you lay it pleat side down on a clean towel or something like that, it should absorb any excess oil.
Doug
dvancleve is offline   Reply With Quote
Old 06-08-2001, 07:08 AM   #4
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Thanks Doug, I will do that before I bolt it on..
Old 06-08-2001, 08:44 AM   #5
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Question
Anyone else want to take a stab at this?
Old 06-08-2001, 05:04 PM   #6
2yLiTe
Member#: 660
Post
I usually leave the filter sitting for an hour or so (during lunch) the just drop it on a piece of cardboard a few times, then wipe any excess off with a towel. I won't be doing this for long though, I've got a Rallispec intake coming soon..
2yLiTe is offline   Reply With Quote
Old 06-08-2001, 05:39 PM   #7
cvalle-sd
Member#: 420
2001 Cr-V
Post
I use the spray can, and go really lightly til the color is uniform. the oil is pretty heavy, so you can put the filter upside down, and stuff a paper towel inside for a while. The excess oil (if any) should pool up and collect. If you use the "pour" bottle, you'll have to let it drip for sure, or put it into a hand-sprayer. Go easy, and be sure to clean the MAF regularly (see other post) I have almost 48k on my original MAF, and have used the K&N cone for most of that time.
cvalle-sd is offline   Reply With Quote
Help Me Please! Uncontrollable Popups! Computer Gurus Rescue Me! Nightwing Off-Topic 32 06-17-2012 10:09 PM
Help Me! Help Me Please! wrxxxappeal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-10-2003 11:14 AM
Going to Japan in a month but have a big decision to make someone help me please!!! Inferno Tri-State Area Forum 23 06-14-2001 01:57 PM
('93-'01) Someone Help me PLEASE!! SubaTubaru Impreza Forum 0 05-04-2001 06:11 PM
ok mechanics, help me please! gimpless Legacy Forum 4 04-10-2001 08:51 PM
