Closed Thread
Old 01-21-2003, 06:56 PM   #1
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Default Electrical Formulas, Basic Electrical information.
In a car we tend to assume between 12 to 14.4 volts as normal
with that in mind...
Here are the basic Ohm's Law calculations...
-The key to the letters-
E = Volts (this is the force of electrons, also known as Pressure)
I = Amps (this is the quanty of electrons, also known as Current)
P = Watts also known as Power (product of Volts X Amps)
R = Ohms (unit of resistance)
to find Amps (I)
I = E/R
I = P/E
I = Sq.Root of P/R
to find Watts (P)
P = E X I
P = R X (I^2) <----I is squared (IxI)
P = (E^2) / R <----E is sq. then divide by R
to find Restance (R)
R = E/I
R = P/ (I^2) <----I is squared
R = (E^2) / P <----E is sq. then divide by P
to find Voltage (E)
E = R X I
E = P/I
E = Sq.Root of PXR (P times R. Then Sq.root the total)
terms
DC = Direct Current
AC =Alternating Current
AWG wire table, courtesy of Ride5000
Wire Table
GLwagon is offline
Old 01-23-2003, 07:31 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Please put all submissions for this thread here:
http://forums.nasioc.com/forums/show...hreadid=305144
munkis is offline
Old 01-23-2003, 07:33 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
FAQ
Q. I just put in seats with out airbags in my WRX, what size resistor do I need to make the air bag light shut off.
A. 3.3 ohms.
Q: What wires do I need to hook up to a starter button?
A: In the ignition harness (under steering column) you need the black one and the black/yellow. Crossing these two with the key in the "ON" position will crank the starter. Cutting the black/yellow one will disable starting with the key.
Q: I blew a fuse, can I replace it with a different rated fuse?
A: No, always replace fuses with the same size/rating.
Q: My parking lights wont shut off
A: Check and make sure the switch on the top of the steering colum is in the off position.
Threads of Note
WRX Fog light MOD
http://forums.nasioc.com/forums/show...threadid=37232
Auxiliary Lighting and Mounting
http://forums.nasioc.com/forums/showthread.php?t=673117
DIY Cruise control light bulb replacement
http://forums.nasioc.com/forums/show...ostid=12840875
munkis is offline
Closed Thread
FAQ and Threads of Note- Read me first! North Ursalia Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-09-2002 05:38 PM
FAQ and Threads of Note- Read me first! North Ursalia Car Audio, Video & Security 0 04-09-2002 05:32 PM
FAQ and Threads of Note- Read me first! North Ursalia Newbies & FAQs 0 04-09-2002 03:52 PM
FAQ and Threads of Note- Read me first! North Ursalia General Community 0 04-08-2002 04:15 PM
FAQ and Threads of Note- Read me first! North Ursalia Interior & Exterior Modification 0 04-08-2002 03:29 PM
