Old 01-21-2003, 07:16 PM   #1
Chris Lawson
Member#: 2210
2000 Impreza RS
Silverthorn
Default would it be possible to swap the roof on a 2000 GC8?
I need to know if its possible to swap the roof with the sunroof thats on my 2000 Impreza 2.5 RS for the standard, solid roof? Any help in this matter would be great. Thank you in advance.
Chris
Chris Lawson is offline   Reply With Quote
Old 01-21-2003, 07:22 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Not easily, not cheaply, and in the end the car will not be very safe unless it is done very well, you would have to cut the roof of and then a body shop would have to weld on the new roof, and if its not done correctly....its just not worth it, put it that way.
why would you want to do this?
Jay
Old 01-21-2003, 07:31 PM   #3
Chris Lawson
Member#: 2210
2000 Impreza RS
Silverthorn
I'm sick of the sun roof and I want to hook up a functional roof scoop. I'll do it when I get back to Cali, I have some connections out there. Thanks for the response. I'm gonna reserch it some more, now that I know its at least possible.
Old 01-21-2003, 07:44 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
anything is possible as long as you have the ca$h
Jay
Old 01-21-2003, 10:44 PM   #5
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
There is a member in the SE Forum that has already done this. It will not affect the safety of the car at all, it may even make it stronger. If I recall correctly the body shop removed the stock RS roof by removing the windsheild & back glass and then just removed the roof skin. They added a cross beam or 2 (factory parts from Subaru from a non sunroof equipped car) and installed a roof skin without the sunroof hole. The "structure" of the car was not cut or altered in any way. I'll search for a relevant link and post it here if I find it.
Opie is offline   Reply With Quote
Old 01-22-2003, 12:56 AM   #6
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
If you're just in it for style and adding the roof scoop (and basically could care less for the extra rigidity) it should be easier to patch over and add a scoop without swapping a whole new roof.. Fiberglass and bondo works miracles
silverF4turbo is offline   Reply With Quote
Old 01-22-2003, 01:04 PM   #7
Chris Lawson
Member#: 2210
2000 Impreza RS
Silverthorn
Thanks for the info Opie. Cash is no issue so no problem.
Old 01-22-2003, 07:33 PM   #8
foolio
Member#: 9351
2006 trailblazer SS
black
Just get one of those rag top slide back junts.
J
foolio is offline   Reply With Quote
Old 01-24-2003, 12:06 AM   #9
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Sean is offline   Reply With Quote
Old 01-24-2003, 02:12 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Old 01-28-2003, 10:22 PM   #11
Roy
Member#: 32241
1998 Impreza L Coupe
white
How difficult is it to put a sunroof on an L coupe?
Would like to have the aftermarket type that "pops up" at the back for increased ventilation.
Is there support structure in the roof that must be modified/removed?
Thanks,
Roy
Roy is offline   Reply With Quote
Old 01-29-2003, 10:00 AM   #12
turbodieselboy
Member#: 5730
You know how they say there is no such thing as a stupid question?
I used to believe that before I read this thread.
turbodieselboy is offline   Reply With Quote
Old 01-29-2003, 10:11 AM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I remember a long time ago someone in Australia (I think) had a conversion that replaced your sunfoor with a roof scoop. You basically took the sun roof out and replaced it with a functional roof scoop.
Eric
Eric SS is offline   Reply With Quote
Would it be safe to turn the car on and move the wheels while on jack stands? Dragonbreak Newbies & FAQs 13 08-17-2007 03:33 AM
would it be possible to pass emissions if... erice1984 Engine Management & Tuning 14 01-30-2005 11:29 PM
Would it be possible to drop a small-block 350 V8 into a WRX? Asinine Off-Topic 29 09-21-2004 04:47 AM
Would it be possible to make your own FP18g? imprezive one Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-28-2003 01:01 PM
would it be possible to run cobb stage 2, 91 oct ecu with stock downpipe. wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-15-2003 07:50 PM
