Old 01-21-2003, 08:02 PM   #1
Pcp03
Member#: 18448
02 WRX
Default horn relocate with cusco strut tower brace
Anyone know of a good place to put it, and also what'd you do with the ac lines?
Pcp03 is offline   Reply With Quote
Old 01-21-2003, 08:15 PM   #2
tdxflex
Member#: 13634
on the side of the pass strut tower there's i think 2 bolts that are just holding brackets up for the o2/egt sensors and some other stuff, just use that and mount it sideways, it's still very audible even facing sideways. The whole thing is actually 2 pieces, the horn and then the bracket to attach to the strut tower bolts so you can take that off.
tdxflex is offline   Reply With Quote
Old 01-21-2003, 08:20 PM   #3
Pcp03
Member#: 18448
02 WRX
thanks, I'll have to try that
Old 01-21-2003, 08:34 PM   #4
Pcp03
Member#: 18448
02 WRX
did you have to lengthen the wire? cause it doesn't seem long enough to mount it there
Old 01-21-2003, 08:43 PM   #5
tdxflex
Member#: 13634
nope, didn't have to lengthen any wires. there should be at least 2 bolts that you can mount it to, just unbolt it and move it around to see which ones it will reach to.
the ac line i just moved the bracket down 1 screw hole and put a little bit of weatherstripping between the line and IC just in case to absorb vibrations better. i've got an sti replica thoguh, i think the cusco's have additional mounting hardware.
Old 01-21-2003, 09:25 PM   #6
Gonz
Member#: 18642
2005 Impreza WRX STi
The Cusco bar leaves less room for the a/c hard lines because it's closer to the firewall. How did you guys with Cusco bar move the a/c hard lines. Did you try to BEND the lines ? They look very fragile/brittle and I don't think they would survive bending, but then I also don't think they will survive rubbing against the bar.
Maybe I'll try the weatherstripping solution.
G
Gonz is offline   Reply With Quote
Old 01-22-2003, 12:02 PM   #7
TubeDriver
Member#: 14987
I relocted the support down one screw (left the top screw off and slightly bent the AC piping downward. It touches the Cusco bar, not really happy with this but it works for now. I was thinking about getting a pipe bender to gently bend the AC pipe a litttle more, only need about another 1/4".
TubeDriver is offline   Reply With Quote
Old 01-22-2003, 12:32 PM   #8
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Yes it will.
bemani is offline   Reply With Quote
Old 08-23-2010, 11:56 AM   #9
krauser2
Member#: 153751
2002 Mazda Miata
The Darkness
Yes it will survive bending....I bent the living hell out of mine and its shows no signs of weakening...that crap is flexible
oh and......THREAD ZOMBIE REVIVAL
krauser2 is offline   Reply With Quote
Perrin TMIC + Cusco strut tower brace? niblick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-15-2009 11:22 PM
FS: Cusco strut tower brace Davidss Suspension/Brakes/Handling 1 10-28-2008 05:41 PM
Need help with rear strut tower brace on '97 Legacy sedan WAFlowers South East Region Forum 6 03-06-2003 09:49 PM
Installed Cusco Strut Tower Brace & Like It! skydiverman Brakes, Steering & Suspension 11 09-11-2001 12:12 AM
