Old 01-21-2003, 09:22 PM   #1
juztin180
Member#: 11804
Default Lost lug key, how to get wheel off now?
I had a flat tire in my driveway yesterday. I patched the tire and ordered a new one to arrive today. I got to the tire place and realized i didnt have my lug key. Thinking it was at home, I came to look for it and its NOWHERE!
I'm not sure how to get the wheel off now. Is there a way to break the lug nut?
its a mcguard locking lugnut. I'm worried about hurting the wheel though, 18" ssr comps aren't cheap
how do i get it off? i have lost the key
juztin180 is offline   Reply With Quote
Old 01-21-2003, 09:45 PM   #2
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
If you're not in rush, I would probably try getting a new key. Otherwise, hammering a slightly smaller socket on the lugnut worked for my Kyokugens when the key was stripped, but the McGard will probably be more difficult. The guy who helped me with the operation had experience because he had lost the key to his locking lugnuts earlier, so the method might work. Do not use an impact wrench (search for my name and Kyokugen to find detailed instructions).
When it happened to me, I thought it was kind of ironic that I intentionally bought lugnuts that couldn't be removed without a special key, and then had to run around trying to find a way to remove them without a key... Good luck!
TheWRX is offline   Reply With Quote
Old 01-21-2003, 09:51 PM   #3
Adick2
Member#: 15064
Default hmm..
I have heard you can use a hardened chisel and try to split the lug. I would not try that unless its a last ditch effort.
Adick2 is offline   Reply With Quote
Old 01-21-2003, 11:03 PM   #4
juztin180
Member#: 11804
well the tire is plugged and its leaking slowly, i need it fixed ASAP
Old 01-21-2003, 11:22 PM   #5
teiva-boy
Member#: 22825
Show me a picture of the lock, and perhaps I can tell you what you need. Back in my young and dumb days, taking off locks was something that I used to do...
teiva-boy is offline   Reply With Quote
Old 01-21-2003, 11:30 PM   #6
teiva-boy
Member#: 22825
Well I just looked at all the wheel locks that Mcgard had to offer, not mentioning the spline drives as those are actually really easy to take off with a normal socket set
What you could try is start with a vice grip the largest one you can get on there completely. Sometime if the wheel wasn't torqued you can take off with that. But it has to be on REALLY tight. In fact to help, you may have to cut grooves or notches in the lock to give the vise grips more of a grab.
The idea of chiseling it off actually does work, but it is a long process and is best with a cutting wheel too. You want to slice into it and use the chisel to finish it off. Since it's hardened steel it should be strong but at the same time it's brittle when it reaches it's extreme. Be prepared to perhaps even replace your wheel stud.
Worse comes to worse, take it to a tire shop. They see this all the time, and can remove just about any lock.
Old 01-22-2003, 12:08 AM   #7
imprezars25
Member#: 26029
2001 2.5 RS
BRP
take it to a decent tire shop, they should have a locking lug nut removal tool. I had mine done at discount tire.
It is a socket that has sharp grooves in it that dig in to the lug when hammered over. makes it really easy. just buy new lugs
imprezars25 is offline   Reply With Quote
Old 01-22-2003, 01:03 AM   #8
juztin180
Member#: 11804
Thanks man. I'll try to talk to discount again and see if they have anything that will work. I asked them today and the guy was like I dont think so..just get your key
Old 01-22-2003, 01:07 AM   #9
juztin180
Member#: 11804
this is the lock that i have
Old 01-22-2003, 01:39 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
PM me if you want, I think I can help without damaging your wheel or stud(If you don't care about the condition of the lock lug, after, that is...). I have the same locks, and my key may even be the same as yours(fat chance, but stranger things have happened).
Good luck
Scott
EDIT: Look for the damn key!
Old 01-22-2003, 01:52 AM   #11
juztin180
Member#: 11804
Good luck
Scott
sent ya a PM
Old 01-22-2003, 02:01 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
Back at ya....
Old 01-22-2003, 02:23 AM   #13
Pcp03
Member#: 18448
02 WRX
I had that happen to my last car, well sorta anyway. The guy who had put one of my tires on somehow over-torqued and couldn't get thenut undone. Impact wrench, three foot long bar, nothing. So he just put his weight on the thing and broke it off. My dad and I went and bought a bolt and put it on there without too much trouble. Kinda extreme, but it worked
Pcp03 is offline   Reply With Quote
Old 01-22-2003, 10:33 AM   #14
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
I asked at 3 or 4 different tire shops, and none of them could really help me. The only one that tried put a socket on it, and used an impact wrench, stripping the lugnut. They said that if they had to remove it, they would use a torch, and destroy the wheel in the process.
Old 01-22-2003, 11:23 AM   #15
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
Have a nut welded to the end of the wheel lock, then just use a regular socket to remove it. To avoid wheel dammage, use a nut only large enough to do the job and weld from inside the nut...not around the outside. If you have lots of room to work outside of the wheel lock, you can use an angle grinder or even a cutoff wheel or dremmel tool to "make" a nut out of the lock. I've done that with a Mustang wheel with great success.
Good luck.
jack
Old 01-22-2003, 01:51 PM   #16
juztin180
Member#: 11804
Went to Discount today, they slammed a socket on with a hammer and used an impact wrench and they came right off. Had to buy new locks though as i lost the info/serial # to get a new lock key
Old 01-22-2003, 03:12 PM   #17
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Yeah i lost my key once and a Discount Tire type joint simply used a vice grip or something and forced my tire locks off. It was a PITA and the locks were trashed but the lugs were ok and i simply bought a new set and tried to hold onto my key this time...
Ed
edkwon is online now   Reply With Quote
Old 01-22-2003, 03:22 PM   #18
DetroitWRX
Member#: 18777
2002 WRX Wagon
Sedona Red Pearl
Sears has a sripped nut removing tool that gets lock nuts off. It's the same thing tire shops use.
http://www.sears.com/sr/product/summ...id=00952160000
They worked for me and they are handy to have around.
Rob
DetroitWRX is offline   Reply With Quote
Old 01-23-2003, 07:54 PM   #19
SubbyRS
Member#: 17193
1991 Legacy RS
yep, that was gonna be my suggestion.....that's what scumbag thieves tend to do!
SubbyRS is offline   Reply With Quote
Old 01-24-2003, 01:28 AM   #20
Ti-REX
Member#: 21741
LGT Limited Wagon +
WRB Wagon STI V7/8
Hence, forget about locking lugnuts.
Ti-REX is offline   Reply With Quote
Old 01-25-2003, 08:44 AM   #21
Adick2
Member#: 15064
Default I doubled posted, I double posted
Im a jack ars.
Thank you and have a nice day/night
Tom
Old 01-25-2003, 08:46 AM   #22
Adick2
Member#: 15064
Default I disagree
I can see it now a thief walking around with an air impact and compressor on his back.
Old 01-25-2003, 12:30 PM   #23
Ethan
Member#: 246
I lost mine once, went to Discount said they would do it, but couldn't gurantee that they could get it off without damaging the wheel. So he gave me one of the many extra locks they have (they were the last ones to use mine so I thought they had it) I got home and was going to pound this lock onto my nuts, but thought I'd look for my lock once more....
Hint...since the lock is black, and the trunk has no light, and if you look for the lock while its nighttime outside, you are not going to find it very well It was in my trunkt the whole time.
Ethan is offline   Reply With Quote
Old 06-15-2005, 02:57 PM   #24
Martinsville
Member#: 89293
Lightbulb Lug lock kits!!!
I just happened across this forum. . . I looked all thru this topic of "Lost lug key" and not see lug lock removal kits mentioned. LL removal sockets are hardened steel impact sockets (smooth, round inner diameter) that are made specificly for lug locks, and can be obtained at just about any autoparts store or tool salesman, er, salesperson. And I have never had a lug lock become damaged by these tools.
Hammering a plain ol' socket on a lug lock can result in damaging a lug lock, splitting the socket, or putting an eye out(face it, not everyone wears safety glasses). I just thought I would mention this regardless of how old the original post.
Martinsville is offline   Reply With Quote
Old 06-15-2005, 05:54 PM   #25
essteaeye
Member#: 88086
05 STi
Black on Gold
Hahah your in luck...
This same thing happened to me right before i traded my car in for the STi, run down to sears or any large hardware store like that, and get a stripped bolt remover kit, or even sometimes that have lug remover set...
Its got reverser threads so as you loosen your wheel the special kit tightenens up and they come off. what a lifesaver! Hope it works for you as much as it did for me, because i was buggine out, i couldnt get my Volk CE28n's off
essteaeye is offline   Reply With Quote
How to get ex. hot now kinda fat girl to lose weight? SubaruRules Off-Topic 88 09-23-2009 03:53 AM
How to get foliatec off? Jeff 2.5RS Brakes, Steering & Suspension 6 12-04-2001 03:28 PM
Tint glue... How to get it off? schlong8 Interior & Exterior Modification 7 10-22-2001 01:12 AM
('93-'01) how to get gum off of my car SubyBean Impreza Forum 1 06-28-2001 11:12 AM
DOH!! Tree Sap on car... How to get it off ? Mizen Technical Forum Archive 9 08-28-2000 02:39 PM
