Old 01-22-2003, 11:11 AM   #1
insanesuby
Member#: 23494
2013 WRX
Default RS-T with J&S Safeguard
Getting ready to wire my new J&S up was wondering if anyone had any suggestions on were to put the unit? Also so all the wires do not have to be run through the engine bay is it possible to use the wiring harness on the stock ecu? Any other info about the install or configuring I would like to hear.
insanesuby is offline   Reply With Quote
Old 01-22-2003, 11:35 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The only wire that has to be run into the engine bay is to the knock sensor they provide. Otherwise everything can be tapped in at the ECU.
Not sure about where to put it... I've seen it under the passenger seat many times, though.
Old 01-22-2003, 11:57 AM   #3
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I had mine mounted in the glove compartment, fit perfect.
Graham
Graham is offline   Reply With Quote
Old 01-22-2003, 12:42 PM   #4
insanesuby
Member#: 23494
2013 WRX
Graham
I think this is what I am going to try.
Old 01-22-2003, 01:32 PM   #5
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Originally posted by 8Complex
The only wire that has to be run into the engine bay is to the knock sensor they provide. Otherwise everything can be tapped in at the ECU..
The new model doesn't bring a knock sensor, it taps right into the stock knock sensor wire in the ECU.
Wedge is offline   Reply With Quote
Old 01-22-2003, 01:41 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Wow... thats news to me. Thanks!
Old 01-22-2003, 07:30 PM   #7
foolio
Member#: 9351
2006 trailblazer SS
black
Mine is under the passenger seat. Glove box would be nice though.
J
foolio is offline   Reply With Quote
Old 01-22-2003, 10:24 PM   #8
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Mines going in the glovebox as well,I have a 2001 so wiring should be the same,Mind showing where and how you tapped the wires for it when your done (if its not too much to ask pix?)
Ben,
Old 01-23-2003, 10:50 AM   #9
Joncas
Member#: 5349
The new one as far as I know still uses the aftermarket knock sensor and it doesn't get connected at all to the factory knock sensor (that is left connnected to the factory ECU).
That being said - my V2 had instructions for my RS that way.
I say put it in the location for the ashtray unless you have the dual monitor - then the glove box. I'm moving mine there now.
(and for those observant people - thats not a subaru compatible J&S - it just so happens I got shipped a single channel unit the first time. Its a dual channel now.)
Joncas is offline   Reply With Quote
Old 01-23-2003, 04:01 PM   #10
TaiChih
Member#: 3467
1998 Dinan3
Bleck
I put mine hidden in the radio center console.
TaiChih is offline   Reply With Quote
Old 01-23-2003, 05:54 PM   #11
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Not sure which model you have.....but, according to these instructions it taps in to ECU pinout B136-4.
Old 01-24-2003, 01:14 AM   #12
Joncas
Member#: 5349
Thats weird... mine came with a different set of instructions showing no connection. Just a separate knock sensor.
J&S SafeGuard knock sensor with Dual Monitor - Protect Your Motor! crashnscar Engine/Power/Exhaust 4 05-16-2008 03:45 PM
Is there any point in running a J&S Safeguard with a UTEC? legacy2003 Engine Management & Tuning 0 02-10-2006 07:28 PM
Problems with J&S Safeguard lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-11-2003 07:00 PM
Anyone blown their engine with J&S Safeguard installed??? FLaBrit Normally Aspirated with bolt-on Forced Induction Powertrain 9 08-25-2003 10:16 PM
help with J&S Safeguard 99SubRs Engine Management & Tuning 4 03-16-2003 05:45 PM
