Old 02-18-2001, 09:30 AM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Post Recomendatoins for a low Boost Controler (5psi)
What it says above^^ I am looking for an electronic or manual boost controler and I want to run very low boost. 5 to 7 psi. What is the best one to go with?
Joshua
Subaru Salesman
yebokmj is offline   Reply With Quote
Old 02-18-2001, 09:38 AM   #2
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
Post
Josh, why don't you want to use the wastegate spring to limit your boost? It might be worth seeing how that does before you go out and spend more money on a boost controller.
RyanC is online now   Reply With Quote
Old 02-18-2001, 09:50 AM   #3
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Post
A spring will always leak a bit. If you want cheap, get a Joe P www.turbologic.com/joepmbc for $50 which will prevent leakage, but not surging. If you want the best control, spend $$$ on an HKS, APEXi or Greddy electronic one.
Jon Bogert is offline   Reply With Quote
Old 02-18-2001, 02:37 PM   #4
yebokmj
Member#: 2213
Brilliant Red
Post
I would idealy like to prevent surging and leaking sounds good to. Any recomendations?
Joshua
Subaru Salesman
Old 02-18-2001, 03:13 PM   #5
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
Post
Read this first:
http://www.i-club.com/ubb-files/Foru...ML/001010.html
then decide if you really need to spend $400+
Old 02-18-2001, 05:29 PM   #6
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
I should have my JoeP MBC this week and installed upon receiving it. I will let you know how well it works at 5psi since that is how it is running.
Aaron http://www.azscooby.com
AaronB is offline   Reply With Quote
Old 02-18-2001, 06:35 PM   #7
yebokmj
Member#: 2213
Brilliant Red
Post
AaronB PM me or do a post on how it is working for you.
Thanks,
Joshua
Subaru Salesman
Old 02-18-2001, 08:00 PM   #8
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
I have a JoeP MBC for my SVX-T that is awaiting an install. Should be soon too.
kastle is offline   Reply With Quote
Old 02-18-2001, 10:55 PM   #9
N/A
Member#: 133
TBA TBA
TBA
Post
You might have wanted to check the www.dsmtrader.com also. People sell alot of their unwanted stuff on there.
N/A is offline   Reply With Quote
Old 02-19-2001, 02:12 PM   #10
DaveK
Member#: 2338
1988 323 GTX
black
Post
I'm getting my turbo kit installed next month. I'm planning on running the same boost levels you are. I ordered the Blitz boost controller. You should be able to find it for under $300. Its got an adjustable high and low setting (min low setting 5psi, min high setting 9 psi) and a button so you can switch between them.
My plan is to only use the low setting for now, and if I upgrade fuel/internals later then I'll use the higher settings.
I think Larry @ imprezars.com is using one.
DaveK is offline   Reply With Quote
Old 02-19-2001, 02:23 PM   #11
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Post
I have the blitz and well no turbo but i won't get into that.. anyway the settings on the blitz should be able to be set lower if you turn the gain down but i won't know till i get my turbo shipped to me...
bill harvey is offline   Reply With Quote
Old 02-19-2001, 06:17 PM   #12
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
I have Blitz with the high setting working as low as 7 psi now, creeping to 8 in 4th and 5th gear under load. When I first got it I couldn't get the high button to give me under 9 psi. The low boost button will let me run as low as the stock wastegate settings of 5 psi (creeping to 7 psi in high gears).
Boost spike is gone, but creep is still there, and I understand a more expensive controller will fix creep if you are set for levels higher than the stock wastegate. I like it for being so cheap ($225 used almost new).
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 02-19-2001, 07:03 PM   #13
RyanC
Member#: 2634
Tornado Red
Post
Innn-teresting... I get no spike or creep with the wastegate-only boost control 'method'. My boost does drop off with rpms though, I'm down to about 4psi or so at redline from ~6 max. How are you recording the boost spikes, on the boost gauge only? I'm curious how the turbo creates the spike?
Old 02-20-2001, 11:29 AM   #14
DaveK
Member#: 2338
1988 323 GTX
black
Post
Larry,
How'd you get the boost controller to let you use less than 9 psi for the high setting. I was hoping to use 5 and 7 psi as my high and low settings. I finally committed to the turbo kit over the weekend. IHI ball bearing! I can't wait.
Looking for a factory boost controller Cyclops NWIC Private Classifieds 10 07-07-2006 06:53 PM
FS or Trade 4 JL audio 12's W0 for intake or boost controller wichitalegacy Private 'For Sale' Classifieds 1 07-01-2006 07:07 PM
help for downpipe and boost controller haroman1188 Newbies & FAQs 6 04-10-2006 05:07 PM
i need some help for my blitz boost control Blitzwrx Engine Management & Tuning 2 09-01-2003 06:28 PM
Looking for electronic type boost controller. Need help with selecting? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 05-19-2002 02:32 PM
