Old 01-23-2003, 12:54 AM   #1
nicktckhoo
Member#: 5836
2002 fake STi
silver and pink
Question Dyno tuning the UTEC and/or ems in general
Hi Guys,
I am bringing my car in for dynoing...4wd dyno. for my stage 3 UTEC setup
How should I start to tune?
I am calling TXS tomorrow but would like to soon you guys out first.
Here goes..
step 1: do a baseline run in 3rd gear to make sure that everything is ok with the engine...check HP, torque, boost, wideband A/F ratios and IDCs....
step2: assuming everything in step 1 is ok. start reducing fuel across fuel map (rpm range) by the smallest increments keeping the values constant across the MAF % readings. when knock is detected at any point in the rpm range start adding back fuel. My question is this way I am basically tuning for WOT and assuming that the fuel settings are safe for part throttle (>60% but <100%)condition. Don't we all drive at WOT?
Or do I do the above fuel reductions and keep an eye on A/F ratios...once it goes above 11, stop and add back fuel at that particular rpm? Better yet, monitor both simutaneously?
step3: start increasing timing across the rpm range evenly by 1 degree. no knock ...proceed by another degree. once knock is detected... note rpm where knock occurred??? Is that possible since I am flooring it?
Is my approach correct? I am assuming the shape of the fuel map and the timing map to be optimal and this may be a wrong assumption. If so How do I tune at specific rpm points? Wouldn't that require an inordinate amount of runs?
Cheers
Nick
nicktckhoo is offline   Reply With Quote
Old 01-23-2003, 11:07 AM   #2
02WRX_BLUE
Member#: 13704
2006 EVO MR
Apex Silver
I would do the same...
UTEC logs do not provide AFR data enough to tune.. So, I would check and adjust the FUEL map.. (But, you should have a specific boost curve in mine so that AFR will be consistant).
I would not run more than 16 PSI with the STOCK turbo. So, I would create FUEL map for 16 psi and another one for 18 PSI (for drag racing and stuff).
As you said, I would do TIMING next to see if you can advance a little with the help from TMIC...
After you are done! Can you send me a copy of map to my email address? : )
Thanks,
Dan from PA.
02WRX_BLUE is offline   Reply With Quote
Old 01-24-2003, 02:14 AM   #3
nicktckhoo
Member#: 5836
2002 fake STi
silver and pink
sure thing Dan
Old 01-24-2003, 11:58 PM   #4
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
Actually... when you get that mapped tuned stop by my website if you wouldn't mind and upload it. =) We've had quite a few people looking for a stage 3 map. Gluck to you. I'll be tuning my stage 2 + headers map tomorrow down in Atlanta on the dyno.
-Tim McKenzie
www.wrxhackers.com
crazyhorse is offline   Reply With Quote
Who wants to get tuned the 20 and/or 21 renosubby Bay Area Impreza Club Forum -- BAIC 0 10-14-2007 03:31 PM
Who attened the Redhook and/or KTR dyno day meets? REDrum New England Impreza Club Forum -- NESIC 10 12-13-2006 10:31 PM
OK..who was tuning the UTEC on their WRB WRX at West Beach Park in Windermere area WhiteWRXBoy South East Region Forum 1 03-02-2004 11:24 AM
Anyplace in So-cal to dyno-tune my Utec? alltractionWRX Southern California Impreza Club Forum -- SCIC 3 01-20-2003 01:45 AM
Anyone able to dyno tune unichip 7-28 or 7-29? Onederer Southern California Impreza Club Forum -- SCIC 2 07-27-2002 09:43 PM
Message Board Statistics All times are GMT -4. The time now is 04:35 AM.
