#1 |
Member#: 20487
Vehicle:2002 wrx blue |
Just curious there is alot of debate at proper installation...I know that the manifold gives the proper numbers because it is not combined gases like the up-pipe, but can you still get accurate readings by installing at the up-pipe? I heard this way is common also....I just want to make sure that it will still work.
Jerry
#2 |
Member#: 4001
Vehicle:2006 Legacy GT Obsidian black |
2" - 3" off the heads on the #3 or #4 runner.
#3 |
Member#: 9782
Vehicle:2002 E46 M3 Laguna Seca Blue |
I read my EGT's from my uppipe, they are about 50-70 degC lower than from the manifold.
I chose the uppipe over the manifold for three reasons: 1. I was worried about the expansion and contraction of the manifold leading to the probe backing out, or even the manifold cracking. I've seen a manifold crack due to a hole drilled for a probe, but IMO it was drilled improperly, and not on a casting button (which is a pretty safe place on the WRX) 2. Putting the probe in either bank's manifild only monitors two cylinders. If something were to do wrong on the other bank (ie: injector failing) it wouldn't show up and could go undetected untill failure. 3. Putting it in the uppipe means I can return the car to stock without having to plug a suspicious hole in the manifold and heatshield. The meter will read faster closer to the manifold, but not because the gas hits it first and the uppipe seconds later (the time it takes to go from the head to the turbo is extreamly short). Heat transfer rate is due to a temperature differential. The larger the difference in temperature, the faster the rate of temperature change at the probe. That basically means that a probe will react faster to hotter gases. Given that there is about a 50-70 degC difference, you will get a faster response at the manifold. The actuall difference in resonse time I don't know, but I'd estimate it to be under 1.0s which on a mildly tuned car is acceptable IMO. -Pete |
#4 |
Member#: 17439
Vehicle:2002 x2 Silver WRX Sedan, White WRX Wagon |
Those are some very interesting points Chunky - haven't really read any "pros" of not putting it in the manifold, but after reading yours, it seems like another viable option. Good stuff!
#5 |
Member#: 20487
so what do you guys do with the stock egt sensor?
Jerry |
#6 | |
Member#: 9782
-Pete |
| Thread Tools | |
| Display Modes | |
| What size wrench to remove EGT sensor in up pipe? | Aspenbullet | Service & Maintenance | 3 | 11-24-2006 08:38 PM |
| question about egt probe and up pipe | crosta21 | Newbies & FAQs | 2 | 03-18-2005 08:18 AM |
| How to get ahold of EGT probe on up-pipe | alltractionWRX | Factory 2.0L Turbo Powertrain | 8 | 03-14-2003 06:10 AM |
| A/F O2 sensor in up-pipe or stock - Results | 2000vfr800 | Factory 2.0L Turbo Powertrain | 1 | 08-31-2002 01:41 PM |
| egt probe on up pipe | mrtrex | Factory 2.0L Turbo Powertrain | 6 | 11-21-2001 07:32 PM |
