Old 01-23-2003, 07:48 PM   #1
AntonioS
Member#: 23233
2000 2.5RS-T
white
Default rwd conversion
I've heard that we can convert a impreza to rear wheel drive... Is it true?? I'm asking because down here in Puerto Rico we don't have a awd dyno and I gathering info about this rwd conversion to see if it is true and I can do it so I can do some dyno runs and know my wheel horse power...please help me
AntonioS is offline   Reply With Quote
Old 01-24-2003, 01:15 AM   #2
NicGordon
Member#: 24827
2008 Kia Spectra
They did this in an article of Sport Compact Car I think. Basically they installed a custom made center differential that only outputs power to the rear.
NicGordon is offline   Reply With Quote
Old 01-24-2003, 04:28 AM   #3
teiva-boy
Member#: 22825
A company in Australia makes a custom center diff replacement for about $400 that makes your subaru into a RWD vehicle.
teiva-boy is offline   Reply With Quote
Old 01-24-2003, 04:06 PM   #4
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
I believe many Subarus with an automatic have a fuse you can pull which makes them front wheel drive...of course this won't help you if you have a manual box.
Stanley is offline   Reply With Quote
Old 01-24-2003, 07:55 PM   #5
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Hmmm...400 for RWD, that would be cool
Too bad the rear dif isnt that big so it would take alot of strain holding all the HP instead of just 1/2
DDMan is offline   Reply With Quote
Old 01-24-2003, 11:14 PM   #6
teiva-boy
Member#: 22825
Lets not forget installation to put that thing in and then revert you back to AWD. It could get very pricey. Better to just buy a spare tranny and keep it in RWD configuration.
Old 01-24-2003, 11:18 PM   #7
SJwrx
Member#: 14970
1997 GF8
multi
Why not buy a turbo RX7 if you guys are thinking about RWD. Subaru is meant for AWD, so use it.
Rich
SJwrx is offline   Reply With Quote
Old 01-25-2003, 04:43 AM   #8
teiva-boy
Member#: 22825
Rich
The RWD conversion product I posted posted is for tuning purposes only. It is a great alternative to road tuning and when you only have 2WD dyno's near you.
Besides you love your subaru too much, AWD is not the end all drivetrain setup.
Old 01-26-2003, 05:50 PM   #9
subyguy2
Member#: 8718
2005 STi, SpecMiata
05 NASA SM - Most Wins
teiva-boy, I completely agree, Ive allways been interested in how it would be to have a rwd RS, and have "thought" about doing it.
subyguy2 is offline   Reply With Quote
Old 07-16-2005, 08:50 PM   #10
mr2pmp
Member#: 76711
2008 Legacy SE
Obsidian Black Pearl
where can I find tech info on the how to of the conversion? my front axles took a dump on my daily driver awd impreza and according to sport compact car, it is very cheap to do this. my specific questions relate to the removal of the front axles. will I have to create a custom cover and seal system for the hole left in the tranny? or can I just remove them and be okay? same for the hubs? And I know I need to weld the spider gears, and that they are reletively easy to get to, but exactly where do I need to weld, or does it even matter? Pics would be a huge plus. I know that this is the ghetto way, but w/ 175K+ miles this car is on it's way out, and I don't want to spend any more dough than i have to. this is on a totally stock 2.2L, 4spd. auto, it is not for drifting or anything silly. It just has to get me around for a little while longer on the cheap. Thanks in advance for any info you all can provide. Now back to the hunt for more info.....
mr2pmp is offline   Reply With Quote
Old 07-16-2005, 09:18 PM   #11
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
get a good wide band and a laptop.
~leor
WRC1 is offline   Reply With Quote
Old 07-16-2005, 09:44 PM   #12
GotTurbo
Member#: 64186
1998 A MONSTER
SOON BMW STEEL GREY
hey i was reading one of my import mag's and they were talking about the sti drift car. what they did to hold all the power cause it is rwd. they put in a skyline rear diff and had a custon drive shaft made to transfer the power. i will find the mag and see if i can post what setup they were using on the drift car.
-matt
GotTurbo is offline   Reply With Quote
Old 07-17-2005, 12:23 AM   #13
Handsdown
Member#: 29355
there have been lots of posts about that drift car. the radiator is in the back seat
but if i were to do a RWD setup it would be to reduce drivetrain loss and be unique. how much drivetrain loss does this get rid of?
Handsdown is offline   Reply With Quote
Old 09-10-2005, 06:36 PM   #14
mr2pmp
Member#: 76711
2008 Legacy SE
-update-
I couldn't find any info on how do do this conversion at all, so I did what any novice mechanic would do - tore into it and figured it out myself. so far the conversion has about 2k miles on it and is doing well. It took two days and cost about 15 dollars - much better than 300 for axles. To my knowledge, I can lay claim to the only rwd, automatic '97 impreza brighton in the land. My next mission is to buy a set of blizzaks and find a lot of sandbags for the upcoming winter. As it is, starting on a hill is tricky in the rain, even with good tires. I would say however that it does turn better at the limit in the dry. It's the same as awd until you start accelerating again. It doesn't slide, but it rotates extremely well mid-corner. And when it does step out, it's still extremely controllable. these are just a few of my findings with a rwd impreza. all in all, I'm glad I did it. It may be a little less functional, but it's worth it for all the fun I can have now. If you are looking for info on the conversion or have questions, feel free to ask. Keep in mind though, it will probably be different with manual trannys or different generations, but I'll try to help.
-peace-
mr2pmp
Old 09-27-2005, 04:55 PM   #15
west005
Member#: 65684
1993 JDM Soarer TT
White on golds
what company makes that center diff for $400? what is the web site?
west005 is offline   Reply With Quote
Old 09-27-2005, 04:57 PM   #16
hanzo918
Member#: 82148
1992 Daihatsu
Charade
Ask Cusco... the JGTC car is RWD...
hanzo918 is offline   Reply With Quote
Old 09-27-2005, 06:04 PM   #17
west005
Member#: 65684
1993 JDM Soarer TT
White on golds
this company has a nice one. Here is the reply!
It's a sleeve that goes in the center diff. It is $815CAD....about $660USD.
Shipping will be under $20 to anywhere in the US.
Jamie Slater,
www.rocketrally.com
front diff/ rear diff/ and RWD conversion supermoose Subaru Conversions 5 09-08-2003 05:16 PM
RWD conversion - will it help? dyswtric27 Transmission (AT/MT) & Driveline 0 06-30-2003 01:56 PM
Auto RWD Conversion ImprezedRS Transmission (AT/MT) & Driveline 4 03-26-2003 07:31 PM
Billet RWD Conversion centre diff chiraoka Transmission (AT/MT) & Driveline 14 01-08-2002 08:04 PM
Anyone done RWD Conversion? cdigerlando Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-25-2001 08:55 PM
