Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 01-23-2003, 07:54 PM   #1
suby ej25
Member#: 3047
2001 Impreza Rs
Default 225/45 17 on a my01 rs?
did a search...can't find anything solid......i know 215/45 17's fit without rubbing......but will 225/45 17 fit without rubbing?......oh yeah...forgot to mention i have a drop....not sure how much of a drop(ground controls).......but it's somewhere between an inch and a half and maybe 2.25..thanks
suby ej25 is offline   Reply With Quote
Old 01-23-2003, 08:17 PM   #2
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
not too sure that they will fit with a drop, but i have had that size tire on my car before and didnt seem to rub. But then again who knows.
I think Pinochle has that size tire on his car.
Billyqua
rally driven.............
RS22b is offline   Reply With Quote
Old 01-23-2003, 08:19 PM   #3
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
From overhearing various conversations I've heard the widest you could go on a RS w/o rubbing or rolling would be a 215.
Mike~~
N'CTRL is offline   Reply With Quote
Old 01-23-2003, 08:22 PM   #4
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
225s with stock suspension will rub at full compression, zephyr ran them last year for auto-x. Not bad rubbing, but just a hair.
-mike
Paisan is offline   Reply With Quote
Old 01-23-2003, 08:22 PM   #5
RidinLow
Member#: 329
1995 325i
Arctic Gray
Pinochle has 225/45 17 on his RS and they do rub. Not sure if removing the rear rubber strip around the fenders solved it, but it should (it did on my Rex wagon).
RidinLow is offline   Reply With Quote
Old 01-23-2003, 08:28 PM   #6
RS22b
Member#: 5413
#15 2-Subaru
P's susp is also dead and is going to be changed to something a bit better tommorrow night.
Billyqua
rally driven................
Old 01-23-2003, 08:29 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Pats tires rub at full compression in the rear and on hard corners.
and I do believe he has 215 45 17s SO3s on 17x8 rota attacks, with stock suspension.
Jay
Old 01-23-2003, 09:55 PM   #8
lo-buck
Member#: 28913
1990 H2 civic
white
when adam ran z's 225 16's they rubbed alot at full compression
lo-buck is offline   Reply With Quote
Old 01-23-2003, 09:59 PM   #9
suby ej25
Member#: 3047
2001 Impreza Rs
Thumbs up
thanks guys...i guess i'm going to go with the 215's..appreciate it
Old 01-23-2003, 11:27 PM   #10
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Pat has 215-45-17 tires on a 7.5" wide wheel
The Rotas cause some rubbing because of the 48mm offset.
I had CE28's with a 50mm offset and they weren't even close to rubbing.
I plan on running 235-40-17 R compounds for auto-X this year.
They should be fine w the suspension and camber done right.Maybe roll the rear quarters a little
jetfan8178 is offline   Reply With Quote
Old 01-24-2003, 08:05 AM   #11
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Whee! Everyone's talking about me!
I have 215/45/17 Bridgestone Potenza S-03s on 17"x7.5" Rota Attacks.
They rub in the rear at full compression.
Pinochle is offline   Reply With Quote
Old 01-24-2003, 08:24 AM   #12
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
They are talking about me too.
I have been running 215/45-17's on my P1's since May and have yet to have any rubbing issues. I was first running Firestone Firehawks and now Sumitomo HRTZII's and I have no problems. I was running with the stock suspension up until about a month ago and now I'm running AGX's with Eibach's and it's still good.
During Autocross I was running 225/50-16's on my stock wheels and I did get some slight rubbing on the rear but that was quickly solved buy removing the rubber strip thing from inside the rear wheel wells. I'm not sure how it will be with the new suspension though.
The only problems I really had was when I was running my 13" gold wire wheels with 155/80-13's. They wern't really rubbing the body though they were rubbing the calipers
Z
Zephyr is offline   Reply With Quote
Old 01-24-2003, 08:57 AM   #13
RidinLow
Member#: 329
1995 325i
Arctic Gray
Pinochle,
Removing that rubber strip didn't help?
Z,
I thought you got the small brake kit in the front & the drum conversion in the back to go with those rims?
Old 01-24-2003, 09:27 AM   #14
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Originally posted by RidinLow
Pinochle,
Haha! That would entail removal of the rubber strip!
Gonna try the stiffer spring approach first.
Hello Suspension Tonight!
(Song of the day: "Tricky" by RunDMC)
"It's tricky to rock around, to rock around..."
Old 01-24-2003, 09:42 AM   #15
N'CTRL
Member#: 29871
Metallic
Damn it, now you got me listing to it.
Next up, "My Adidas".
Mike~~
Old 01-24-2003, 10:02 AM   #16
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Mike~~
*Ding-ding ding-ding ding-ding-ding ding-ding ding.
Ding-ding ding-ding ding-ding-ding ding-ding ding.*
"You be illin'!"
Old 01-24-2003, 10:12 AM   #17
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Oh right the small brake kit. Yeah but you remeber what happened with that when I tried to slow down for a Chicago Box.
That's how I ended up with the Cone Killer of the Year award.
Z
Old 01-24-2003, 10:13 AM   #18
RidinLow
Member#: 329
1995 325i
Arctic Gray
Yeah man, you should've hit the switches upon corner entry, you might've been able to clear that outside section of cones.
Old 01-24-2003, 10:21 AM   #19
subarugt
Member#: 11053
99 Legacy GT LTD
Rio Red
Guys,
225/45/17 is a tricky one for the GC's. They might fit with the right offset and camber, but is it really worth it for the marginal more handling. I would stick with the 215/45 since their is no problem with that.
As fas as 225/50/16. There is slight rubbing with the stock suspension. With a stiffer suspension and not much drop it SHOULD not rub, but it is a tight fit.
For AutoX though the increased diameter is a benefit over the litlle rub. I will be running this size on my Legover next year with KYB AGX shocks and stock springs. This year I ran 205/45/16 witch I felt was too small. I did give a gearing advantage, but autoX is all handling.
subarugt is offline   Reply With Quote
Old 01-24-2003, 10:40 AM   #20
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Yeah maybe if I had hit the switchs and done a little three wheel motion or dog legged it I could of avoided the cones but I wasn't quick enough.
Z
215/45-17 or 225/45-17 on an '05 RS sedan? Columbia1991 Tire & Wheel 4 02-24-2010 03:03 AM
('93-'01) 225/45/17 on 2.5 RS? RallyGuy2k Impreza Forum 8 04-06-2008 07:13 PM
225/45/17 on 2.5 RS? RallyGuy2k Texas Impreza Club Forum -- TXIC 10 03-01-2008 02:21 PM
225/45 17 on 2000 RS? Need help quickly. willguidry Tire & Wheel 1 04-18-2003 11:58 AM
215/45/17? or 225/45/17 on SDRs Costas Brakes, Steering & Suspension 4 02-11-2003 08:09 AM
