#1 |
Member#: 451
NWIC
Vehicle:2000 Impreza 2.5RS 2008 Legacy GT Limited |
Right now I have a JC Sports Intake with an MRT vent scoop directing cold air on it
My main Questions was that with the scoop on some rain water will be falling onto the top of the cone air filter... Is this a major problem if the filter gets wet? How could I protect it better? Would a Pre-filter from ISR help?
#2 |
Member#: 3231
RMIC
Vehicle:88 626 Turbo white |
i have a jcs intake and when it snows i will be putting the backing plate back on. once i forgot to put it back on at the car wash it did okay so... the oil should protect it if i understand correctly the function of oiling the filter...
#3 |
Member#: 1259
Vehicle:1999 Impreza RS Rally Blue Pearl |
Probably not a huge problem if it is just a drip, but I would play it safe and try to manufacter something to alter the course of the drop away from the filter
#4 |
Choke Artist
Moderator Member#: 603
NESIC
Not a problem at all. Obviously the filter wont flow quite as good as it would dry. But that's not nearly enough water to hydrolock your engine or anything. It's really not much different than water injection if you think about it. Harmless.
#5 |
Member#: 451
NWIC
Well right now I have a plastic piece bent around the cone filter to protect it from the water (being in the Northwest you have to figure in that it will be raining alot)
Another concern would be that the plastic catching on fire from the heat of the engine, but it just seems like it gets flimsy Thanks |
#6 |
Member#: 756
Vehicle:2003 Legacy L wagon 2009 Kawasaki C14 |
I highly doubt the plastic would catch on fire from the heat. If it did, then they wouldn't use plastic for all the intake tubing. As far as water getting on the cone filter: I have a similar set up with the bonnet scoop dumping air directly on the filter. The only thing that I notice is that the filter gets dirty really quick. I'im not even worried about my engine sucking up enough water to hurt it.
Jim |
| Thread Tools | |
| Display Modes | |
| WTB: K&N Cone Air Filter | bugeyeblue | Private 'Wanted' Classifieds | 1 | 08-24-2007 04:51 PM |
| paper cone air filters with 5" ID? | nhluhr | Factory 2.5L Turbo Powertrain | 0 | 11-02-2005 02:51 AM |
| FS: used Impreza/Legacy 1995-99 Cone Air Filter adapter $3 on eBay | Jude DeMeis | Private 'For Sale' Classifieds | 0 | 03-25-2005 03:22 PM |
| ('93-'01) Cone Air Filter Conversion | ImprezaVA | Impreza Forum | 8 | 02-20-2003 03:01 PM |
| FS: (2) Cone Air Filters and Gauge Cluster | AJ711 | Mid Atlantic Impreza Club -- MAIC | 1 | 06-30-2002 06:37 PM |
