Old 04-17-2001, 11:33 AM   #1
jacksonww
Member#: 5181
1997 Legacy GT
Post Abnormal Clutch noises?
I will try my best here.
Right below the air filter, on the right, near the fire wall, there is a mechanism that seems to be part of the clutch.
What is happening at idle or when the clutch is pressed is that this piece tends to chirp as if it is rubbing on rusty metal. I WD40'd the sucker to death but it will not stop and actually is getting louder.
I located a what looks to be a rubber dust boot below it and sprayed WD40 down there as well but still no luck.
If it helps I was told by a muffler shop guy it sounded like the throwout bearing was going out. Not too sure he knew what he was talking about.
Any help would be appreciated
Thanks
Jack
jacksonww is offline   Reply With Quote
Old 04-17-2001, 02:53 PM   #2
datpnoy2nv
Member#: 4841
1998 2.5RS/SE-R
Black/wGold RIms/Slate Gr
Post
I have the same chirping sound on my 98 2.5RS Impreza. My mechanic told me the same thing (throwout bearing). Mine starts chirping when the pedal is slightly depressed and sometimes when at idle. The only way to remedy that is to change the throw out bearing however, while your down there you might as well upgrade the clutch if you want.
datpnoy2nv is offline   Reply With Quote
Abnormal Turbo Noise water_fiend Factory 2.0L Turbo Powertrain 3 08-12-2006 07:28 PM
STI Clicking Clutch Noises at 12K? Two different noises MidnightSti05 Transmission (AT/MT) & Driveline 1 08-27-2005 01:57 PM
99 obs clutch noise and hatch noise only1agam Service & Maintenance 5 06-11-2004 12:00 AM
('93-'01) Clutch noise, did a search... Jazz95 Impreza Forum 3 05-12-2001 02:45 PM
Clutch noise? Herman General Forum Archive 6 11-14-2000 10:45 AM
Message Board Statistics All times are GMT -4. The time now is 01:11 PM.
