Old 02-28-2001, 02:21 PM   #1
speedracer47
Member#: 2765
Post
Mine sort of does that too when starting cold. When I still have the clutch pushed in after starting its fine, but when I release it in neutral, I hear the scraping and definate difference in the sound of the engine. Could this be a problem with the clutch?
MY00 RS, 25k miles.
speedracer47 is offline   Reply With Quote
Old 02-28-2001, 04:37 PM   #2
M a t t
Guest
Member#:
Post
mine does that too. i dropped it off at the dealer to see if they could reproduce it, but it wouldn't work for them. also it was really warm that night.
Old 02-28-2001, 05:28 PM   #3
Pinoy
Member#: 400
1990 300ZXTT
Post
maybe its the belts??? maybe... Try some belt dressing on them and see if goes away.
Pinoy is offline   Reply With Quote
Old 03-01-2001, 12:44 AM   #4
Yeoman
Member#: 175
2000 Impreza 2.5RS
2012 Legacy 3.6R
Unhappy Scratching/Scraping sound when cold starting
As soon as the car motor engages, right after I turn the key, and when its cold. (left for about 8 hours). The engine does a quick little SCRATCH sound. Like something is scraping against something else. Metal to metal. Has this happened to anyone else? And if so, what was done about it. I'd like to know before I have to leave it overnight at the dealer.
BTW, 2K RS with 27000kms on it, it's been happening since just this winter.
Yeoman is offline   Reply With Quote
Old 03-01-2001, 10:10 AM   #5
Yeoman
Member#: 175
2000 Impreza 2.5RS
2012 Legacy 3.6R
Post
Geez, it seems its not common, = bad news!
its not after I let go of the clutch, its just after the key is turned for a split-second but very noticeable. Guess I'm gonna have to bring it in... thanks guys.
ScRaTcH!!!
Old 03-02-2001, 12:26 AM   #6
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Post
Mine makes a weird noise when I start it up after it's been sitting for a while. But, after that it's fine.
redobs is offline   Reply With Quote
Old 05-18-2010, 01:09 PM   #7
OncInc
Member#: 247064
2010 Impreza
Hello. I am new to the forum. I am resurrecting this thread because I have a similar problem to my Impreza. It is a newly bought 2010 model with only 500 miles on it. And no after-factory undercoat job is performed.
To reproduce the problem, I park the car overnight, then start the car. When I accelerate (gentally not hard), there is a scratching noise from the bottom underneath the rear right passenger seat area. The noise is soft but is still noticeable, and it lasts momentarily (for about 0.1 second). After that, the car will start normally without the noise for the rest of the day. And it is reproducible every day I start my car first time.
I left my car overnight at the dealership for testing but the technician claimed he could not hear it even though I test drove it with him and heard it myself. So I have no choice but to leave without solution.
Does anyone know what this noise is? It is not a loud noise but I doubt it is normal for a brand new car. Should I wait for it to wear off?
OncInc is offline   Reply With Quote
Old 05-18-2010, 08:49 PM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
right rear of the car? could be parking brakes not wanting to let go. does it matter if you're moving forward or backward?
Old 05-18-2010, 08:53 PM   #9
vrusso
Member#: 207074
2015 STI
You know you're jealous
when you turn your car on do you just go straight to cranking it over or do you give it time for the fuel pump to prim and then crank? I would turn the car to the on position without cranking it wait till you hear the fuel pump finish then start the car and see if you hear the same sound.
vrusso is offline   Reply With Quote
Old 05-20-2010, 12:41 AM   #10
OncInc
Member#: 247064
2010 Impreza
Forward/backward does not matter. And the noise happens when I apply gas.
Old 05-20-2010, 12:43 AM   #11
OncInc
Member#: 247064
2010 Impreza
I cranked it over. I will try your suggestion and see. Thanks
Old 05-20-2010, 12:54 AM   #12
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You got weasels....
Old 05-21-2010, 02:59 AM   #13
dome24
Member#: 111845
97 RUBAsU Tall2dr
04 FXT VF22/COBB AP
I have a similar sound on my 03wrx, after start up for a second or two I get a sound like a starter holding but its a highr pitch sound. I know the starter holding sound and this is not quite the same.
I usually let my walbro pump prime a couple times before I start it.
dome24 is offline   Reply With Quote
Old 05-23-2010, 12:43 AM   #14
09_'preza_OBS
Member#: 220049
2009 Impreza OBS
Obsidian black/dark grey
Mine does the same thing from an overnight cold start after rolling forwards about 15-20ft. I have 10k miles on mine and no prob at all. Dare I say "they all do that." But I wouldn't worry about it
09_'preza_OBS is offline   Reply With Quote
Old 05-23-2010, 04:52 PM   #15
kgeezy
Member#: 241559
1999 impreza 2.5rs
Rbp
mine makes the exact same noise after a cold start. but if the engine is warm then it doesnt happen. i have a 99 2.5rs with 120k
kgeezy is offline   Reply With Quote
scraping sound when decelerating ? Jonnathan Service & Maintenance 8 07-09-2007 04:31 AM
Watery sound when cold started? dcwrx2 Transmission (AT/MT) & Driveline 3 10-08-2005 04:45 PM
Scraping sound when turning on A/C codemunky Service & Maintenance 1 05-14-2005 05:53 PM
I know this sounds stupid... but Louder boxer sound when cold.. SubaruImpreza_power Normally Aspirated Powertrain 43 01-16-2004 11:19 AM
Stage 0 and strange sound when cold starts..... WRXPTY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-23-2002 11:27 PM
