Old 04-29-2001, 09:19 PM   #1
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Post Green "test" connectors.
There are two green connectors, one on the passenger side and one on the driver's side under the dash. If you plug them in the fans cycle and the coil doesn't get juice. Anyone know the purpose of these?
-Simon
Really_Soaked is offline   Reply With Quote
Old 04-29-2001, 10:04 PM   #2
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Post
No one?
Old 04-30-2001, 08:20 AM   #3
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Talking
The Green connectors serve 3purposes that I'm aware of;
1st) When the car is new and in transit to the dealer, they are connected. This puts the engine in a "lean run" mode to prevent the plugs from fowling. When the cars are in the factory, port, transit, etc. they are not driven enough to warm them up, maybe 50 feet at a time.
2nd) They are referred to as the "D-check" connectors (Dealer check or Diagnosis check). A technician will connect them and then perform certain tasks in a particular order and this will cause the ECM to test itself.
3rd) As you found out, when they are connected, it causes the various fans, relays, solonoids, fuel pump, to cycle on-off. A technician can use an instrument called a Subaru New Select Monitor (NSM) to isolate individual components and cycle them by themselves. This is known as Forced Drive.
SubyTechMaster is offline   Reply With Quote
Old 04-30-2001, 08:28 AM   #4
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Post
Thanks for the answer. Would this, for any reason cause the coil not to have power?
Old 04-30-2001, 04:27 PM   #5
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Post
No, plugging these connectors together will not prevent the engine from starting/running. As I wrote previously, this is used as a diagnostic. If you have no power at the Ignition coil, you have another problem.
Old 05-01-2001, 01:00 AM   #6
kaminari
Member#: 1781
2000 2.5RS
Blue Ridge Pearl
Post
I also heard that the green connectors on the driver's side are used (it AUS cars, probably JDM cars too) in conjuction with some black connectors in the area to do a "proper" ECU reset (read MRTs site about it)
but nobody I know of has been able to locate said black connectors, just the green ones.
-jason
[edit]forgot to add "on the driver's side"[/edit]
[This message has been edited by kaminari (edited May 01, 2001).]
kaminari is offline   Reply With Quote
Green Test connectors bdon22 Commercial ECU Reflashes 47 05-04-2007 12:44 PM
where are the green test connectors (lgt) vogun16 Commercial ECU Reflashes 6 04-30-2007 09:11 AM
Green test connector and white connector...AP Q styng88 Mid Atlantic Impreza Club -- MAIC 6 03-06-2006 02:08 AM
Green test Connectors already connected hnasko Engine Management & Tuning 6 08-01-2004 06:25 PM
Accessport and green test connectors zojirushi Engine Management & Tuning 0 06-24-2004 01:59 PM
Message Board Statistics All times are GMT -4. The time now is 02:05 AM.
