Old 04-29-2001, 10:00 PM   #1
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Post Engine Overheat
I have just experience a very scary senario...while playing cathup with a civic and integra...my99 legacy 2.5 GT was experiencing a very high overheating characteristics...my gauge was in the middle of the "H" on my engine temperature gauge...so I stopped playing and pulled of to a safe area...With the car in stopped and parked my oil light came on, flickering at first!!! Then I smelled radiator fluid...I popped the hood and saw that the resevoir overflowed...there is radiator fluid everywhere on the front rightside of the engine...I checked my oil and it was perfect, so I assume I didnt blow the oil pan gasket...the radiator hose was rock solid with enormous pressure and very very hot I might add!!! While letting it sit for 30 min. I then drove it immediately home where again it went back up to "H"!!!
I did noticed that my heater no longer works as well as A/C!!! I put on hot it give me outside air...I put it on A/C and its like the compressor isnt on!!! WHAT GIVES???
SO WHAT IS THE PROBLEM???
Is it a blown thermosat???
Do I need a radiator flush???
I am taking it to the dealer tomorrow morning hopefully it wont cost me an arm and a leg!!!
PLEASE ADVISE!!!
and THANKS!!!
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 04-29-2001, 10:10 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
<FONT face="Comic Sans MS">Most likely the thermostat is stuck shut... that would cause the hose to turn rock solid with built up pressure, backing things into the overflow. Also, it's the cheapest thing to replace first
Brian
AIM: captaindamorgan ICQ: 84483950
http://ravensblade.cjb.net
You and the Captain make it happen!</FONT f>
Old 04-29-2001, 10:23 PM   #3
Mike Moffa
Member#: 27
9805 STi V3 -LegGT05
Rally Blue - Satin White
Post
Like North Ursalia said, check your thermo first.. But I had the same problem with my car.. and It was a blow head gasket, and the pressure was going back, and make the thermo stay close, and hte engine to overheat, and make the coolant overflow... Hope for you its not that.
Let us know man.
take care
Mike M
Mike Moffa is offline   Reply With Quote
Old 04-29-2001, 11:28 PM   #4
mcgyver
Member#: 1655
MY98 RS w/WRX Conv
I-Speed Tech
Thumbs down
Yup,
I had the same problem, resulted in blown head gaskets.
Apparently, the design of our engines makes the thermostat stick closed when the gaskets are blown. The combustible gases build-up behind the thermostat. They also pressurize the cooling system and push-out the coolant, hence coolant in the overflow bottle and all over your engine.
I had the same problem for many months, even did it after I removed the thermostat.
You should be OK, as long as you're under the 5yr/60k drivetrain warranty.
Adam
mcgyver is offline   Reply With Quote
Old 04-30-2001, 04:13 AM   #5
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
I concur, classic symptoms for our Subarus with blown head gaskets. Also of note is that your MY99 GT is a DOHC similar to the MY98 RS, which have a history of head gasket problems. (I know, too.)
Steve
http://www.forcefed4.com/
SteveS is offline   Reply With Quote
Old 04-30-2001, 04:16 AM   #6
Thug
Choke Artist
Member#: 603
Post
Sounds like a head gasket.
Thug is offline   Reply With Quote
Old 04-30-2001, 06:52 AM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Exclamation
what year is your GT ken??? 99... just like mine eh...
well mine did that... just once... and briefly...
overheated... thermostat got stuck..
result??? cylinder #2 blew... new short block.... weak arse Phase I engines!!!
Likely your car will need either a new head gasket or a new short block...
stop driving the car NOW...
and get it into the shop.
have them run hydracarbon tests... today!!
Phase I engines... sucks dont it...
j. www.subiegal.com
[This message has been edited by Subie Gal (edited April 30, 2001).]
Old 04-30-2001, 07:04 AM   #8
Thug
Choke Artist
Member#: 603
Post
Actually, if it's still under warranty, I would personally drive it a little more. A new short block for free would be nicer than a new headgasket for free. Although you would likely be w/o you car for a while.
ABS, Airbag, and Rear Diff light on after washing engine Acejam2k Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-02-2010 12:32 PM
Engine Overheat At 50,000 Miles!!! sube-trex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-04-2005 05:48 PM
Overheat problems Ti-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-10-2003 11:48 AM
help overheat red of the sun Service & Maintenance 16 12-28-2002 11:25 AM
('93-'01) Engine Overheat, CE light problem Piusma Impreza Forum 11 06-04-2001 05:35 PM
