Old 04-29-2001, 10:58 PM   #1
gronemeyer
Member#: 645
1995 Glacier White
Impreza L Sport Wagon AWD
Question oil leak-bottom timing cover
I have oil leaking from the bottom of where the black plastic (timing?) cover meets the aluminum. There appears to be a gasket between these two surfaces, but is there supposed to be oil inside there? or is it leaking from somewhere else? It's a pretty big leak that started after I changed the oil and performed a tune up.
I also have another very small leak from the front of the head, the oil leaks down and around onto the exhaust flange bolt.
Thanks,
-Gronemeyer
MY95, 1.8L, 127,000 miles
gronemeyer is offline   Reply With Quote
Old 04-29-2001, 11:00 PM   #2
oldpreza
Member#: 5259
1995 Impreza
Post
sounds like the dreaded oil pump problem.
oldpreza is offline   Reply With Quote
Old 04-29-2001, 11:16 PM   #3
gronemeyer
Member#: 645
1995 Glacier White
Question
The dreaded oil pump problem? Please tell me more.
I was just looking at a shop manual. Looks like the plastic timing cover also covers the oil pump assembly.
So, are you telling me the oil inside the timing cover is leaking from the oil pump?
EJ257 Bits: Oil Feed Lines, Timing Covers, STI Valve Covers, Timing Gears,Oil Pan etc DSM_Outback Engine/Power/Exhaust 16 10-20-2009 01:01 PM
i need the bottom timing cover gasket. ASAP!!!! wrxej205 Private 'Wanted' Classifieds 4 03-07-2009 03:09 AM
Oil leak from timing belt cover g-rider Service & Maintenance 5 07-01-2008 08:25 PM
Oil Leak from timing belt cover abosworth Normally Aspirated Powertrain 26 09-15-2005 08:29 PM
Oil Leak at Valve Covers question Baluchitherium4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-31-2003 01:11 PM
