Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 04-17-2001, 06:42 PM   #1
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Question Gauge???
I have a MY99 Legacy 2.5GT...I have installed already a dual gauge pod in the middle of my dash (sort of like the mustang)...it has a Air/Fuel Ratio Meter (red/yellow/green) and a Fuel Pressure Meter (0-100 psi)...I am about to buy a dual piller gauge pod and am not sure what gauges I should get in addition...I am running my car naturally aspirated with a CAI, Magnecor wires, NGK Plugs, Borla Headers (Gen 3), JC Sports 2.25 cat-back w/o resonator, Unorthodox pulley, Synthetic oil, MSD DIS-2, and a Zex kit with a 55hp shot...I am shooting for a EGT and a Oil Pressure gauge!!!
What 2 gauges should I get instead???
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 04-17-2001, 06:54 PM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Those 2 gauges are the gauges that I was going to suggest : EGT and Oil Pressure Gauge. EGT is important because you have a NOx setup. Oil pressure is always good to have just in case oil pump fails or there is a big oil leak that you don't know about. Instead of oil pressure, maybe oil temp, or even vacuum/boost gauge.
I have oil pres., A/F, and voltimeter on my car along with SAFC which shows engine vacuum because I have a MAP sensor.
tmat3 is offline   Reply With Quote
Old 04-18-2001, 08:18 PM   #3
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Post
Thanks Tmat3 for the reply!!!
I will defintely go with the EGT, but oil pressure or vacuum/boost???
What doesvacuum/boost monitor and why would I be interested???
CRAZY KEN
Old 04-19-2001, 04:25 AM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Well, you know what the oil pressure tells you.
Vacuum is important to know because that tells you any potential leaks and cracks in the engine. You will see a diagram in most service manuals, but too less vacuum means there is a leak in vacuum line or even headgaskets. This is more like a health meter for your engine. If you ever going to get a SAFC, you don't need this though.
I personally would go for oil pres. and EGT, just like you said. Also, you have NOx, right? How about a Nitrous pressure meter?
FS : JDM 660cc Injectors-GFB Lightweight Pulleys-AEM Wideband-Various Turbo Gauges-MORE! Audioexcels Engine/Power/Exhaust 37 11-02-2010 03:34 PM
FS : Prosport Blue/White - Oil Pressure and Water Temp Gauges - $30 each - NJ danman765432 Interior/Dressup/Audio & Security 7 06-13-2010 06:16 PM
FS/FT : FS/FT NorCal OEM Gauge hosing for 02-07 WRX **SOLD** ztotheh Interior/Dressup/Audio & Security 0 06-01-2010 01:23 PM
CA: Gauging interesting in OEM gauge pod and gauges BlackRex22 Private 'For Sale' Classifieds 20 10-29-2003 06:28 PM
Gauges, gauges and more gauges arrghh! trustWRX Newbies & FAQs 2 08-25-2003 01:43 PM
