Old 04-18-2001, 07:12 AM   #1
9
Member#: 4074
1998 Impreza RS
RBP (one of the first!)
Post oil pressure gauge
this might be a dumb question, but would an oil pressure gauge let you know if you were loosing oil or just if oil is being pumped through your engine? i gues what i mean is if oil pressure dropped could that be an idication that you were loosing oil? thanks in advance.
9 is offline   Reply With Quote
Old 04-18-2001, 07:18 AM   #2
Nat
Member#: 759
2004 WRX
2000 SV650
Post
I really don't think an oil pressure guage would let you know you are loosing oil until you are pretty much screwed. As long as there is a minute amount of oil that can be pumped, it will show up as pressure on the guage. This could, or could not, be enough oil to keep you from seizing things up. I still want one though, I think oil pressure guages are one of those nice things to see. On my older car (66 Pontiac) it helps me see when it is warmed up enough to drive.
Nat is offline   Reply With Quote
Old 04-18-2001, 07:24 AM   #3
25psi
Member#: 3086
2001 2.5 RS
Post
Well, actually if you do pay attention to the gauge you will notice that you are loosing oil. It will not go as high as it used to uder same conditions.
Eugene
25psi is offline   Reply With Quote
Old 04-18-2001, 05:36 PM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
25psi is right. If you lose oil, there will be less pressure. Also if you have oil temp gauge, oil temp will go up as you lose oil. Less oil = more heat.
The idiot light comes on when you lose way too much oil also. But, by the time the idiot light comes on, your engine is almost gone forever.
tmat3 is offline   Reply With Quote
Old 04-19-2001, 01:56 AM   #5
Jay_UK
Member#: 296
Post
An oil pressure gauge will not display any signs of an oil leak, unless the level drops below that of the oil pickup.
At which point, you are probably about to ruin your engine.
Check the oil on a weekly basis...along with water and other fluids.
The stock oil warning light sucks.. the sensor is set to something like 2.5 psi.. and if that comes on... get the check book out for a new engine...
J.
[This message has been edited by Jay_UK (edited April 19, 2001).]
Jay_UK is offline   Reply With Quote
Old 04-19-2001, 06:03 AM   #6
9
Member#: 4074
1998 Impreza RS
Post
well thanks a lot guys. the reason i posted this queston was more along the lines of helping me decide what gauges to get not about if my car is leaking oil, i know it is slightly i can smell it burning, and i check it like every two or three days and know that the level is going down slightly more everytime till i put more oil in it, unfortuantely i dont have the time or the space in my garage to fix the problem correctly, but now that i got my charger almost done i should be able to work on it this weekend. well thanks again.
FS: autometer gauge pod, autometer oil pressure gauge, maddad EGT gauge schiarelli Interior/Dressup/Audio & Security 2 10-29-2009 11:26 AM
Oil Change -> Oil Temp and Oil Pressure gauge malfunction??? hostile silence Electrical & Lighting 3 04-18-2009 11:41 PM
Oil Pressure gauge to read fuel pressure? PeteDucati Interior & Exterior Modification 0 03-02-2007 11:35 PM
Oil Temp or Oil Pressure Gauge? drees Electrical & Lighting 11 09-23-2003 11:29 PM
oil temp. and oil pressure gauges kenken325 Vancouver Impreza Club Forum -- VIC 18 09-25-2001 12:15 AM
