Old 03-06-2001, 11:45 AM   #1
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Question Need New Plugs and Wires Any Suggestions
Hi everyone. I need a little help. I am at the point were I want to replace my plugs and wires and I want to use something better than stock. What should I buy.
Later Z
Zephyr is offline   Reply With Quote
Old 03-06-2001, 11:50 AM   #2
DigDug
Member#: 4077
1999 Impreza 2.5RS
Talking
For plugs, NGK platinums, available from your local dealership. I don't think anyone would dispute the fact that NGK reigns supreme for spark plugs. And platinums will last a lot longer than coppers.
For wires, I hear the stock wires are as good as any. I know that Magnecor sells their KV85 comp wires for the Impreza, but I really doubt you need anything beyond the stock wires. Plus, those wires are expensive! Magnecors are something over $100/set last I checked. And the stock ones aren't cheap, either - the dealership quoted me something like $65 for the set!
DigDug is offline   Reply With Quote
Old 03-06-2001, 11:50 AM   #3
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Post
Befor someone says it rudely try a search, you can ge a wealth of info. There is a topic in this forum right now on plugs. That said get some NGK BKR6E-11 plugs. the 00 and 01 came with crap Champion plugs. Wires are not a big concern unless yours are worne but you can get some mangacore wires.
Josh
scoobiejosh is offline   Reply With Quote
Old 03-06-2001, 11:52 AM   #4
jeffg
Member#: 2958
2001 WRX (GC8)
Post
I must admit, I have been converted with Denso plugs. After a month or so of break in I am getting 300 miles per tank with aggresive street driving. The only other mods I have are an Amsoil replacement filter.
Wires, Magnecore are good.
Nothing against the NGK, I have run NGK in all my other toys...
jeffg is offline   Reply With Quote
Old 03-06-2001, 03:18 PM   #5
blitzpb
Member#: 1646
2007 Spec
Post
I am using the Denso Iridiums on my turbo RS. These ar the same plugs as HKS I believe and they are cheaper. I think I paid 60 for the set though, so not that cheap. I cant remember the part number, sorry.
Nick
blitzpb is offline   Reply With Quote
Old 03-07-2001, 12:03 AM   #6
DigDug
Member#: 4077
1999 Impreza 2.5RS
Talking
Better yet, NGK PFR-5B11's. These are the platinum plugs with the proper heat range for our non-turbo application (unless, of course, you have a turbo, in which case, you would be better off with colder plugs, like 6 or maybe even 7).
Needs new Plug and Play harness for my Bugeye JDMs... MDBlackWRX Electrical & Lighting 1 04-28-2010 01:02 AM
plugs and wires and fluid time? Oh my! Kev5n24 Baja Forum 20 06-26-2007 11:17 AM
i need new plug wires no good Legacy Forum 5 11-30-2005 01:39 AM
I need yellow spark plug wires! Any suggestions? Alpine Sube Interior & Exterior Modification 4 06-11-2001 04:33 PM
