Old 04-17-2001, 11:41 PM   #1
oldpreza
Member#: 5259
1995 Impreza
Post Hard Shifting
Had my car for 6 months now and haven't got a reason why my gear is so hard to shift from any gear to 2nd gear. Double clutching helps sometimes. It's usually after sitting for a couple of hours and just started up. i crawled under the car today and found all the shift links intact and nothing messing it up down there.
oldpreza is offline   Reply With Quote
Old 04-18-2001, 12:11 AM   #2
RS-LOVER
Member#: 4463
2000 Impreza RS
Blue Ridge Pearl
Post
Mine does the same. I miss shifts all the time. I just think its our stock trans. If you get a shifter kit it supposedly fixes it.
RS-LOVER is offline   Reply With Quote
Old 04-18-2001, 03:04 AM   #3
NA Impreza
Member#: 4267
1999 rs
white
Post
sometimes it's really hard for me to get into reverse.....i have to shift to 1st then to reverse.....anyone with the same problem?
NA Impreza is offline   Reply With Quote
Old 04-18-2001, 03:40 AM   #4
Sir Yacho
Member#: 5716
1993 Legacy Sport
Silver, mostly
Post
I've got the same problem shifting into reverse. Sometimes it goes, sometimes I've gotta play around a bit before it engages, I dunno.
Hopefully there's a cheap fix or adjustment for this? Anyone?
Sir Yacho is offline   Reply With Quote
Old 04-18-2001, 05:50 AM   #5
EchoWrx
Member#: 4101
2000 Impreza
Lightbulb
Try flushing the clutch fluid with Synthetic dot 4 brake fluid. Also try Redline 75w90ns oil for front trany and 75w90 for rear diff. When I changed mine at 9000 miles there were metal flakes everywhere. If that doesn't help then it might be the master/slave clutch cylinder or worse the throw-out bearing. Anyway, mine is hard to shift too.
good luck
Gill
EchoWrx is offline   Reply With Quote
Old 04-18-2001, 09:30 AM   #6
HKscooby
Member#: 4466
2001 Impreza RS
Blue Ridge Pearl
Post
i do got the same problem. everytime i shift from 1st to 2nd or 3rd to 2nd. i actually need to force the shifter in. and somwtimes when i put in reverse, i also need to make a few try. the shifter just won't get into reverse gear. but one thing that i know is that u have to have a complete stop of the car to shift into reverse, if not, u'll hear a "grouch" sound. this tranny problem i've realize since i got the car from the seond day.Really dunno how to fix. i wanna get it smooth like a Bimmer's gear box.
ciao.
HKscooby is offline   Reply With Quote
Old 04-18-2001, 09:36 AM   #7
Delhi
Member#: 4511
Post
no problems for me here. Try pushing your clutch pedal all the way in.
Reverse is hard cus there's no synchro. What you can do is before going to reverse, shift to first or any other forward gear and then go reverse.
Delhi is offline   Reply With Quote
Old 04-18-2001, 10:13 AM   #8
oldpreza
Member#: 5259
1995 Impreza
Post
try double clutching for the revserse prob... there's no synchro, so need to double clutch. it works for me.
but the 2nd gear is a real pain... i might flush and change my front trans fluid next week to see
Old 04-18-2001, 10:17 AM   #9
oldpreza
Member#: 5259
1995 Impreza
Post
will a RS shifter fit my 95 impreza L?
i heard that it's slightly shorter
Old 04-18-2001, 10:40 AM   #10
Arch
Member#: 1881
2001 Impreza 2.5 RS
Blue Ridge Pearl
Post
Double clutching into reverse works for me too.
Arch is offline   Reply With Quote
Old 04-19-2001, 01:04 AM   #11
Blindeye_03
Member#: 4418
2016 Focus ST
Post
Mine is hard to get into 1st gear sometimes...even from a start.
Blindeye_03 is offline   Reply With Quote
Old 04-19-2001, 01:53 AM   #12
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
Post
I don't really have the second gear problem, but I get the reverse thing all the time. I usually end up double clutching, but it's frustrating. And I hate that it makes a nasty noise until you come to a dead stop.
Marc
Marc Sawaya is offline   Reply With Quote
Old 04-19-2001, 09:41 PM   #13
oldpreza
Member#: 5259
1995 Impreza
Post
Does anyone know if the pre-02 RS shifters:
1. will fit my 95 1.8 L?
2. shorter than my stock shifter?
Old 04-19-2001, 09:45 PM   #14
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Post
No 2nd gear probs, but my reverse is finicky. Some times multiple double clutch trys does not do it either. I will try the foward/reverse thing.
ChosenWon is offline   Reply With Quote
Old 04-19-2001, 09:48 PM   #15
Blindeye_03
Member#: 4418
2016 Focus ST
Post
it should fit...if its just the handle part.
Old 04-19-2001, 09:55 PM   #16
IowaRS
Member#: 5385
2012 WRX Base
Ice Silver
Post
Subaru builds a tight transmission that takes a while to break-in.
It will last forever though.
I recommend changing the tranny fluid too.
It always helps shifting, even if you replace it with fresh stuff of the same kind.
IowaRS is offline   Reply With Quote
Old 04-19-2001, 09:56 PM   #17
NA Impreza
Member#: 4267
1999 rs
white
Post
is double clutching into reverse the same as just regular double clutching while downshifting? should i just give it some gas before pressing in the clutch?
[This message has been edited by NA Impreza (edited April 19, 2001).]
Old 04-19-2001, 11:59 PM   #18
SubaTubaru
Member#: 5343
97 Legacy GT
4 tone red
Post
guys dont make the reverse thing orse than it really is... all it takes is... if it does not engage while putting the car in reverse... VERY slowly let up off the clutch.. it will slip in every time. i do not honestly knwo the mechanices of it, but truthfully, double clutching is nto necessary. just do as i said... LIGHTLY and SLOWLY let up on the clutch and it slips right in.
Mike
SubaTubaru is offline   Reply With Quote
Hard shifting Chapel Transmission (AT/MT) & Driveline 6 04-06-2003 06:49 PM
hard shifting from 1st to 2nd in my93 L quentinberg007 Transmission (AT/MT) & Driveline 3 08-01-2002 03:01 AM
Really hard shifting FriendOfSubaruOwner Legacy Forum 15 12-21-2001 01:40 AM
