Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 02-28-2001, 04:48 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Post Anyone with experiance installing JC Sport Torque Chip II?
I am doing the install tonight and everthing makes sense exept for the following. There is a Temp from sensor conection, temp to ecu conection and then a Temp modifided conection. Where does this modifided connect? Do I conect along with the temp sensor to ecu? Help?
Joshua
Subaru Salesman
yebokmj is offline   Reply With Quote
Old 02-28-2001, 05:50 PM   #2
yebokmj
Member#: 2213
Brilliant Red
Post
anyone?
Old 02-28-2001, 06:45 PM   #3
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
If I remember correctly, one lead is for the actual engine temp, and the other is to fool the ecu into thnking the engine is colder than it really is. But I forget what that accomplishes. Hope this helps.
Bill
96Lconversion is offline   Reply With Quote
Old 02-28-2001, 09:20 PM   #4
tluzziracing
Guest
Member#:
Post
josh, i just installed one a couple of weeks ago.cut the temp sensor wire a couple of inches from the ecu.the wire going away from the ecu,attach the temp sensor wire from the tc2.the wire going into the ecu,attach 1 of the 2 temp wires from the tc2.there are 2 wires on the tc2,USE ONLY 1!.the modified wire will really give you more fuel.the regular wire (temp wire to ecu)will just slightly modify the fuel.do not use the modified wire,only if your car is running very lean.
you will have 1 wire you will not use.pm me if you have any questions with your turbo install,being that i just did the same install 3 weeks ago.john at JCS is very helpful too.
tony
Old 03-01-2001, 04:42 AM   #5
yebokmj
Member#: 2213
Brilliant Red
Post
Thanks Tony, your a life saver no one at JC Sports seemed to be able to answer it for me. I will be putting it in this morning.
Joshua
Subaru Salesman
Old 03-01-2001, 04:51 AM   #6
AndresRS01
Member#: 2401
2002 Toyota Mr2
Post
Tony , hi
How do you like yours??
I suppose to get mine any day.
What kind of improvements did you feel?
Mine suppose to raise the rev limiter red line also.
Thanks for the input
Andres
AndresRS01 is offline   Reply With Quote
Old 03-01-2001, 11:22 AM   #7
scoobadoo
Member#: 4567
Post
hey dude, hows the turbo going. Is it running any better than last night? CHUG CHUG WOOOOSSSSHHHH!!!
scoobadoo is offline   Reply With Quote
Old 03-01-2001, 09:23 PM   #8
tluzziracing
Guest
Member#:
Post
andres,
do you have a turbo?or are you n/a.
i installed mine when i put the turbo in,so i noticed alot of improvements.
Old 03-02-2001, 11:58 PM   #9
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
That is correct, one of the temp wires is not used - you can fool the motor into thinking it is colder and get more enrichment if you use the modified wire to feed the signal back to the ECU instead of using the regular temp wire.
I wonder if his would be good for a modded NA car with a fuel pump that doesn't have a RRFPR to add more fuel.
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
JC Sports Torque Chip II Problems Rainierez Engine Management & Tuning 2 04-19-2005 05:24 PM
JC Sports Torque Chip Install Directions? StankFootZ Normally Aspirated Powertrain 12 10-31-2002 08:13 AM
I hate to cross like this, but need help with JC sports Torque chip JGard New England Impreza Club Forum -- NESIC 0 03-14-2001 04:00 AM
does anyone have the jc sport torque chip zx2boy Legacy Forum 0 03-05-2001 06:10 PM
JC Sports Torque Chip II subarumantoo Normally Aspirated Powertrain 34 01-30-2001 12:34 AM
