Old 03-28-2001, 08:38 AM   #51
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
50, wow, this is my longest post, seems like I sturred the hive, lots of people out there unhappy with JC Sports. It's not fair to gang up on them lke this, but they should at least address this topic, saying nothing makes it even worse.
96Lconversion is offline   Reply With Quote
Old 03-28-2001, 10:16 AM   #52
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
Post
I just ordered the chip a couple day ago, I'm expecting it anyday now and when I install it I'll let you all know if it was worth the money. I spoke to JCSPORTS on the phone and told them some of the negative things I heard about the TC2 and they assured me not to worry an that I would be satisfied. For those that asked of it works with automatics, JC told me NO, that the CE light will come on, on auto's.
SuBart is offline   Reply With Quote
Old 03-28-2001, 10:19 AM   #53
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
will come on or will not come on?
Old 03-29-2001, 12:31 AM   #54
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Post
Alright, I went out and bought a voltmeter just now. So I should be able to probe the intake temp signal and the MAP signal to see what kind of differences I get on my TC2.
Optimally it'd be nice to have a multichannel device with logging capability so some graphs could be produced and some analysis could be done. But this should at least be a start.
If I get a chance to do some test runs tonight, I'll post my results.
iodine23 is offline   Reply With Quote
Old 04-08-2001, 10:20 PM   #55
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
bump
Old 04-23-2001, 08:53 PM   #56
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
bump, JC SPORTS, any dyno results yet????
Old 04-24-2001, 08:50 AM   #57
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Figures, they don't even try to support their own name, let alone their products...lets see if Rimmer can resurect his name from the ashes.....JCS obviously cant.
STiShawn is offline   Reply With Quote
Old 04-24-2001, 09:35 AM   #58
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
Well, it's quite hard to access a 4wd dyno up here... I'll be posting some G-tech results for the TC2 later this week.
GTBGUY is offline   Reply With Quote
Old 04-24-2001, 09:38 AM   #59
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
Thanks GTBGUY, if you could post a stock RS G-Tech run and your car with only the TCII, that would be great! Thanks again
Old 04-24-2001, 11:10 AM   #60
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
Guys, it will be tested on a Legacy GT, don't have access to a stock RS to test it on. However, I have access to a friend's stock Legacy GT. So the gains will be relavent
Old 04-25-2001, 03:00 PM   #61
zx2boy
Member#: 2869
1999 legacy GT
green
Post
i have had the tec II for about a month
at first it didnt do anything but after a week it was alot faster . instructions are
a bitch i called them and they said dont hook this wire and that wire ,so i was like there is only 2 wires left ,so i said screw it and hook them all up except for the modded temp wire
zx2boy is offline   Reply With Quote
Old 04-25-2001, 03:09 PM   #62
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
zx2boy - should've read my instructions first!
here's a link to the instructions for anyone doing it themselves :
http://www.i-club.com/ubb-files/Foru...ML/002335.html
Old 05-11-2001, 02:53 PM   #63
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
GTBGUY, did you post your results anywhere yet?
Old 05-11-2001, 03:32 PM   #64
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
96Lconversion - They will shortly be posted (b/c benefits are seen 2weeks to 1month after install.) I have the runs from a stock car though.
Old 05-11-2001, 04:25 PM   #65
tulit
Member#: 338
09 STi
Post
GTBGUY, I think its best to let them know you are a reseller of JC Sports products. That way, they can keep that in mind when analyzing your results.
tulit is offline   Reply With Quote
Old 05-12-2001, 10:55 PM   #66
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Talking
The JC Sports torque chip's designer is very good with electronics, is reclusive and does not frequent this board, and does not wish to give up proprietary information that could lead to other's copying his design. I agreed to edit this message to protect the design as well.
It is not JCS that is being deceptive or secretive - rather the designer chooses to limit what information that he dispenses to JCS and others, and then let the results (and customers) speak for themselves. This is reasonable to protect his interests.
Anyways, some descriptions here are accurate, except that it intercepts the engine coolant temp signal, not the air temp signal. But either way, fooling the ECU into thinking the motor is cooler will make it richer. This is not all it does...
My experience with the TCII is this. Before I got it, I was running the plain JCS Boost Chip (map voltage clamp only) with an S-AFC when I first did my turbo kit. I had the S-AFC set for as much as 18%-25% enrichment from 3K - 5K rpm, and couldn't enrich above that because of the MAP voltage clamp. I had to rely on the RRFPR to enrichen the top end. So, I changed to the TCII.
My first test drive at 5 psi with the TCII, after pulling out the S-AFC was dramatic. No changes in any thing else (and RRFPR settings were left alone), and it pulled harder right out of the box without training the ECU. There was no mistaking the improvement, and while butt dyno's can lie, this was not a false sense of acceleration from something like more noise, etc... Over time it only got better. I still needed the RRFPR for extra fuel under boost, don't get me wrong; but it definitely does something to be able to enrichen as much as the S-AFC did before the TCII.
Dyno time is expensive, and I don't see JCS doing any pulls in the immediate future while they are re-structuring with a new business model right now. A few people have posted positive results (burninrubber's NA car is much better with torque chip for example), and right now we all just have to decide whether to believe what TCII owners have to say, since you won't believe JC Sports. I have always had a good reputation for being trustworthy, and I say this was a worthwhile mod for me, and would be a good mod even for an NA car.
I wish I had dyno'd my car before and after, to help out here. But at $100 for three pulls on the 4WD dyno, or $175 an hour, I didn't want to.
Hope this helps...
Larry www.ImprezaRS.com
[ June 06, 2001: Message edited by: ImprezaRS dot com ]
ImprezaRS dot com is offline   Reply With Quote
Old 05-29-2001, 11:59 AM   #67
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
anyone have results yet?
Old 06-06-2001, 06:10 AM   #68
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
tttttt(to the tip-tip-tippity-top)
Old 06-06-2001, 09:00 AM   #69
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
Post
We'll see if it's a hoax, my car is at my mechanics right now and the Jc's torque chip is getting put in right now as I type this reply. I'll let you all know if it's a hoax or not after I drive it for a couple days since it supposedly takes sometime to program itself. But you are supposed to feel some difference immedialty according to JC Sports. Let's see what happens.
Old 06-06-2001, 09:03 AM   #70
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
GTBGUY was supposed to post some of his results but I don't think he ever did. Where are you??? I need info!!
Old 06-07-2001, 12:05 AM   #71
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
Ok here's some G-Tech Pro data :
Stock (1998 Legacy 2.5GT, 5spd), tested on a +20C day, at Calgary, Alberta, Canada altitude. Using 91 Octane gasoline, brand new OEM Subaru Air&Oil filter as well as 5w40 Castrol Syntec Synthetic Oil.
0-100km/h (0-62mph) = 8.7s
1/4 mile = 16.9s
Fuel efficiency = 10.2L/100kms city driving
Stock + JCS TC2 (1998 Legacy 2.5GT, spd), tested on a +20C day (same as above). Using 91 Octane gasoline. (Results after 30days with brand new OEM Subaru Air filter, same oil as above.
0-100km/h (0-62mph) = 8.4s
1/4 mile = 16.2s
Fuel efficiency = 9.88L/100kms
Edited to include fuel consumption.
[This message has been edited by GTBGUY (edited June 06, 2001).]
Old 06-07-2001, 07:41 AM   #72
Scoober01
Member#: 3649
2001 Impreza 2.5 RS
Blue Ridge Pearl-Red acc
Post
I'm dumb. nuff said.
[ June 07, 2001: Message edited by: Scoober01 ]
Scoober01 is offline   Reply With Quote
Old 06-07-2001, 07:46 AM   #73
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
Scoober, those results are pretty good, and they will probably get better with time. What other $250 mod will shave .3 seconds off your 0-60 time and .7 seconds off of your 1/4 mile?!?!? I am definitely going to get one, as long as they let me return it if I am unsatisfied. I want to wait till I get my MRT exhaust system though
Old 06-07-2001, 07:49 AM   #74
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
BTW, thanks for the results GTBGUY, much appreciated!
Old 06-07-2001, 08:03 AM   #75
tulit
Member#: 338
09 STi
Post
How can you consider those results accurate? They were taking 30 days apart.
A lot of other things other than air temperature will affect the results.
Could have been different winds, air humidity, launching in a different manner, etc.
Does anyone have the certificate from MAZDA for $$ off from going to Rev-It up? 03WRXMA New England Impreza Club Forum -- NESIC 9 07-14-2004 04:19 PM
ok, so anyone have test results from the FP 18g? 1WikdWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-19-2003 03:08 AM
anyone have the mudguards from get primitive? ^jynx^ Interior & Exterior Modification 8 07-21-2002 05:25 PM
Does anyone have a midpipe from a GC8 Impreza I can buy or have? BrysImpreza New England Impreza Club Forum -- NESIC 5 02-17-2002 11:54 AM
Anyone have some pics from the Utah Meet? t-bone Rocky Mountains Impreza Club Forum -- RMIC 0 06-08-2001 10:40 PM
