Old 04-30-2001, 03:45 PM   #1
Herbie
Member#: 415
2002 WRX Wagon
2002 BMW Z3 3.0i Coupe'
Question ECU/Wiring Harness Questions...
OK folks, there's a 1.8L '93 Imp here in town that's caught my eye as a second project car... I'm in CA which means I need to pass a fairly rigorous visual inspection before the biannual tailpipe test.
Engine changes are allowed, but only if ECU and smog gear are also swapped.
If I DO get a project car, it needs to be smog-legal, or easily retrofittable to smog legal.
So, with all that in mind, my questions:
What years of Engine/ECU/Wiringharness are compatible? I know there were a couple of changes in ECU connectors along the way somewhere, so not all ECU's will plug into the same harnesses.
For example, as much as I'd like to swap a legacy turbo motor into this beasty, I know that'll require major wiring rework.
Anyone know what options I have for an easy/painless swap?
My other option would be to drop in a turbo motor and use a standalone ECU to bypass the wiring harness altogether, but this leaves me having to do an engine swap every two years to pass the smog. Major drag and expense.
Any other thoughts?
Herbie is offline   Reply With Quote
Old 05-01-2001, 02:15 PM   #2
Herbie
Member#: 415
2002 WRX Wagon
Post
OK, no dice on this one apparently. Not too much info in the archives after a search either.
I'll try another tack:
Anyone care to relate their experiences swapping wiring harnesses on various engines?
Where to find a WRX engine/ecu/wiring harness? Texas25RS Texas Impreza Club Forum -- TXIC 11 05-02-2005 07:01 PM
'94 WRX ECU/wiring harness, etc FS Matt Monson Private 'For Sale' Classifieds 3 12-08-2004 03:18 PM
Fs: 2005 Sti Engine/ecu/wiring Harness, 900 Miles latinskllz Private 'For Sale' Classifieds 2 10-11-2004 10:41 AM
JDM version 6 STI motor,transmission,ecu,wiring harness boost master Private 'For Sale' Classifieds 10 08-30-2004 02:25 AM
pins for factory ecu wiring harness recursian Electrical & Lighting 0 12-17-2002 08:51 AM
