Old 01-25-2003, 12:04 PM   #1
moojamboo
Member#: 17343
Default crush washer for oil pan
hey guys
can i go about changing my oil while using the same crush washer? I know that i should change it, but i don't have one now, its saturday, the oil should be changed, i have the oil.
is this REALLY going to matter for one oil change?
Thanks
Matt
moojamboo is offline   Reply With Quote
Old 01-25-2003, 12:28 PM   #2
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
I've heard no.
you can try it, I have a lifetime supply (or pretty damned close so I don't have to worry about it)
speed safely
Brian
Slvrblt is offline   Reply With Quote
Old 01-25-2003, 01:59 PM   #3
MMastro
Member#: 18230
1993 EG Civic/ITR
Last time I changed mine I reused the old one, and I haven't had any leakage problems. I wouldn't re-use it more than twice though. The worst thing that would happen is a very slow leak I think.
MMastro is offline   Reply With Quote
Old 01-25-2003, 03:18 PM   #4
AndyWRXWG
Member#: 23784
2005 M3
Tiag
I reused mine with my first oil change and had a slow drip leak from the bolt. But all it took was a quick tightening and it was fine. If you don't have a new one I wouldn't worry to much just make sure you get the bolt tight. Probably not a good idea to use it to many times. By the way how much do they charge for those things at the dealer, and are they only available there or can you get them at parts stores?
AndyWRXWG is offline   Reply With Quote
Old 01-25-2003, 03:33 PM   #5
SFastWRX
Member#: 13379
I am Oz
I've got just two words: Fumoto Valve.
SFastWRX is offline   Reply With Quote
Old 01-25-2003, 03:35 PM   #6
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
I got away with it the first oil change, but not the second. I just went to the dealer and bought a bunch. The problem is trying to put the new washer in place after you already have 5 quarts of Mobil 1 in the car.
pegdrgr is offline   Reply With Quote
Old 01-25-2003, 05:13 PM   #7
scottm1978
Member#: 13284
That is very interesting cause I have used the original one about 15 time now and have never had a leak or sign of one.
scottm1978 is offline   Reply With Quote
Old 01-25-2003, 05:19 PM   #8
sr20det91
Member#: 26508
MY05 EVO VIII
Wicked White- 03RR Sold
I'v used the same one for the last 10 changes,(original one actually) with no leaks at all. Just make sure you put it on the same way it came off. Meaning flat side against the oil pan. These things are a sales gimmick ,I'm sure. As soon as I get around to it I'm gonna replace it with a copper washer and be done with it.
sr20det91 is offline   Reply With Quote
Old 01-25-2003, 05:19 PM   #9
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Yeah I used the same one for about 5 changes. But now have the fumoto valve.
MAD REX is offline   Reply With Quote
Old 01-25-2003, 06:21 PM   #10
moojamboo
Member#: 17343
cool guys, thanks for the help
Old 01-25-2003, 09:46 PM   #11
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
I think people have a misunderstanding regarding the puropse of a crush washer. It helps to ensure you don't over tighten the drain plug and damage the pan/threads. The "crushing action' of the washer helps accomplish this (hence the name). Also, it helps ensure the plug doesn't slacken during the period until your next oil change. Since the washer is crushed as you tighten it, you will need to replace it once removed.........otherwise it doesn't do it's job.
Regards,
Kean
Kean is offline   Reply With Quote
Old 01-26-2003, 12:57 AM   #12
schmleff
Member#: 14669
2002 WRX Wagon
Gents,
You do not need a new washer at every oil change but you will need to anneal it by heating it with a torch and quenching it quickly in cold water. That will make it nice and soft to provide a good seal. We do it on aircraft sparkplug washers as a standard practice.
Schmleff
schmleff is offline   Reply With Quote
Old 01-26-2003, 09:01 AM   #13
Bottom Feeder
Member#: 2808
Same here. I'm not running to the dealer for a new one before every change.
Bottom Feeder is offline   Reply With Quote
Old 01-26-2003, 12:42 PM   #14
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The crush washer on my car was leaking from day one, so I've been using solid copper ones instead and no more leaks. I do have the oil temp sender/drain plug instead of the standard one but I don't think that should matter, the seating surface is the same.
Old 01-27-2003, 02:34 PM   #15
Tex-WReX
Member#: 7107
2014 Mustang GT
NAPA gold oil filter- FIL1334 or just ask for 1334
NAPA drain plug gasket- 704-1963
If you have NAPA, this is another option
I bought 10 a year ago, no problems. I also use a small amount of PTFE tape.
John
edit direct link for more info
http://www.napaonline.com/cgi-bin/nc...grpid=46115192
Tex-WReX is offline   Reply With Quote
Old 01-31-2003, 03:19 AM   #16
SJwrx
Member#: 14970
1997 GF8
multi
I think the crush washer is more of REALLY cheap insurance. 25cents per oil change X 40 oil changes in the Subaru's life = $10 whole dollars you say buy not changing the crush washer.
Rich
SJwrx is offline   Reply With Quote
Old 01-31-2003, 09:57 PM   #17
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Same here on my '95 Legacy. Don't worry about it.
Mike Wevrick is offline   Reply With Quote
Old 02-01-2003, 09:43 PM   #18
slater
Member#: 5848
1992 vw corrado vr6
silver w/ schrick/quaife
amen to that!
slater is offline   Reply With Quote
Old 02-11-2003, 12:06 PM   #19
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
How well does a Fumoto Valve hold up to salt and dirt?
WRX03 is offline   Reply With Quote
Old 02-12-2003, 11:04 AM   #20
subyguy2
Member#: 8718
2005 STi, SpecMiata
05 NASA SM - Most Wins
Ive had to reuse it, didnt have any leak problems, but you probably dont want to use them more that twice like they said.
Chris.
subyguy2 is offline   Reply With Quote
Old 02-12-2003, 05:20 PM   #21
Frederf
Member#: 15622
2002 WRX SW
I went to Tahoe and came back, and the valve action was smooth and unobstructed.
As far as the body of the valve itself is concerned... the thing is built rock solid.
Frederf is offline   Reply With Quote
Old 02-12-2003, 08:28 PM   #22
Bottom Feeder
Member#: 2808
Rich
Insurance against what?
Old 02-12-2003, 08:32 PM   #23
Karl
Member#: 13110
Against non-sealing drain pan bolt. Oil leaks, anyone?
Karl is offline   Reply With Quote
OEM Oil Filters and Crush Washers for Sale NewbieWRXer Private 'For Sale' Classifieds 0 04-01-2005 10:12 AM
Crush washer for oil change chubb Service & Maintenance 43 10-28-2004 10:31 PM
Crush Washer - first oil change Peaty Newbies & FAQs 0 08-04-2002 04:45 PM
Crush washers from oil pan ok for Tranny pan? HomerJay Normally Aspirated Powertrain 2 07-14-2001 04:24 PM
Need to buy crush washers for oil change, where? Necromancer Bay Area Impreza Club Forum -- BAIC 7 08-06-2000 08:50 AM
