Old 04-30-2001, 03:08 PM   #1
dandbest
Member#: 1885
2015 Evo
Post Hit the rev limiter today...
Hello all, today I was messing arround with my friend's RX-7, and in 3rd I hit the rev limiter. It kicked in at like 6400-6500RPM. Now, this wasn't on purpose, I usually watch the tach, and make sure I shift at like 6000RPM but today I just wasnt paying attention and... My question, did I hurt anything? The motor sounds fine, but I feel bad... Could what I did cause damage in the future? Anything I could check? Any input will GREATLY APPRECIATED.
Danny
dandbest is offline   Reply With Quote
Old 04-30-2001, 03:16 PM   #2
ninetalesnwf
Member#: 3739
85 R30 skylineGT-T
Red/black
Post
you should be fine
a short burst of over reving wont damage anything.
Just dont do it for more than 10 seconds then something could blow then it wouldnt be a good day for you
cya
ninetalesnwf is offline   Reply With Quote
Old 04-30-2001, 03:28 PM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Rev limiter is there for that reason : stop the engine from overrevving before it's too late. I do it all the time when autox-ing. Everything is fine. Just don't keep it at that speed for a long time.
tmat3 is offline   Reply With Quote
Old 04-30-2001, 07:06 PM   #4
dandbest
Member#: 1885
2015 Evo
Post
Thanks! I sure will remember to watch the tach the next time...
Danny
Old 04-30-2001, 07:20 PM   #5
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Sounds of a scooby on a medium speed auto-x
dah-dah-dah-dah-dah....
your engine is good to 7k dont worry about the rev limiter, its an idiot switch. I hit it several times a week.... just dont hold it there unless racing.
Midwayman is offline   Reply With Quote
Old 05-01-2001, 04:41 AM   #6
Thug
Choke Artist
Member#: 603
Post
Im mustve hit mine 25 times at Sunday's auto-x.
Thug is offline   Reply With Quote
Old 05-01-2001, 05:31 AM   #7
JayP
Member#: 3125
2001 Mustang Bullitt
Post
I'll hit mine 3 times before I pull out of my garage!
JayP is offline   Reply With Quote
Old 05-01-2001, 07:36 AM   #8
Willis
Member#: 424
2005 WRX STI
Post
hahaha, oh yeah, I hit mine 3 times before turning the key
Willis is offline   Reply With Quote
Old 05-01-2001, 03:26 PM   #9
2yLiTe
Member#: 660
Post
but if I understand correctly, the rev limiter only works if you're accelerating. If you were going all out in 3rd, and then downshifted to 2nd, the rev limiter won't do anything for you when the tach goes over right? or will the rev limiter cut you back?
2yLiTe is offline   Reply With Quote
Old 05-01-2001, 03:40 PM   #10
T-WReX 2.5RS
Member#: 5105
2000 Impreza
Post
Guys and gals,
Guess what day is it everyday?
It's Hit-the-limiter-day
hehehe...
J/k...I don't usually hit it.
Unless street-beating Si-s.
Regards,
Tony.
T-WReX 2.5RS is offline   Reply With Quote
Old 05-01-2001, 04:19 PM   #11
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
when you downshift from 3rd to 2nd (or anyother gears from higher to lower), the rev limitter will not kick in. Actually, it will kick in, but it will be too late. Let's say the engine is running at 5500RPM at 3rd gear, and you downshift to 2nd gear. Most likely the RPM will be in the 7000 RPM area.
Old 05-01-2001, 04:32 PM   #12
pottsie350
Member#: 6110
98 Impreza L
Red
Rev limiters were made for smacking into. At least once in a while. I can tell just when mine is about to kick now. Probably the worst strain they cause is the shuddering in the driveline as the engines dies and fires etc. I can tell you it's a shock when you run into on a GSXR, I thought I broke the thing it cut the engine off. The gixxer excelerates so hard when the enine died it felt like it was going to throw you over the bars.
pottsie350 is offline   Reply With Quote
Old 05-02-2001, 01:47 PM   #13
kapnk
Member#: 4890
2001 Impreza RS
Post
6500 isn't dookie for an rx-7. my '85 12a bridgeport(stock internals except for larger volume oil pump, high pressure oil relief valve, and of course, the ports) hits 8000rpm
on a daily street driven basis. 8000-8500 is the limit for 2piece apex seals(what all of them use from the factory).
kapnk is offline   Reply With Quote
Old 05-02-2001, 09:28 PM   #14
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Post
I remember the needle burying itself past the limit on the tach of my '88 RX-7 (9800+RPM) it wasn't a pretty sight, but for some inexplicable reason the old girl was still fine...
Really_Soaked is offline   Reply With Quote
Old 05-03-2001, 05:15 AM   #15
dandbest
Member#: 1885
2015 Evo
Post
No, what I meant was that I was racing with my friend who has a RX-7. I know those cars can go to 8000RPM. I have a 01RS.
Danny
Old 05-03-2001, 06:27 PM   #16
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Post
funny you should mention that... I had to test the rev limiter the other day. Hpirally and I were out for a ride, and it occured to me, that I have never red lined my car. I generally only pull it to 5.5 or so, maybe 5.9 if I'm pushing. So... wack... about 6.45 is my estimate... fun stuff
AO
m750 is offline   Reply With Quote
Hit the rev limiter today :( buccilli15 General Community 42 07-16-2006 10:38 PM
I hit the rev limiter at 5000 in first only ChungerSuby Newbies & FAQs 27 04-13-2005 07:36 AM
Has anyone encountered a problem with the engine caused by hitting the rev limiter? MulletSlayer Motorsports 25 08-11-2004 09:28 PM
Car feels like it hits the rev limiter when it's not hitting the rev limiter Tainted Transmission (AT/MT) & Driveline 21 01-09-2002 12:21 PM
Hit the rev limiter? Skirvdawg Normally Aspirated Powertrain 13 04-22-2001 07:40 PM
