Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 04-18-2001, 06:21 PM   #1
Jessie James
Member#: 2072
Post Uh... where's the fuel line?
Okay, I hooked up my fuel pressure gauge sender to what I *thought* was the fuel line from the tank. But that only reads about 12 psi...
So which line is the high pressure fuel line from the tank?
I've got a MY00 Impreza, and picked the line that comes in to the engine compartment, goes over the black canister, then into the top silver line. It's secured with a phillips-head screw clamp. Line below it is secured with a tension clamp. The other line (that goes onto the copper colored line) is also an option.
Help me out so I don't have fuel spraying everywhere!
Jessie James is offline   Reply With Quote
Old 04-19-2001, 07:23 AM   #2
Homicidal Maniac
Member#: 1612
2008 STI
I located the fuel rail on the drivers side and then traced the incoming fuel line back a little and tapped off there. The line goes from the fuel rail to the fuel filter so make sure you tap after the filter but before the fuel rail. I can go take a quick picture of my car if its still unclear.
Old 04-19-2001, 07:40 AM   #3
Member#: 1655
MY98 RS w/WRX Conv
I-Speed Tech
The Fuel Filter is Printed with IN & OUT on it. That is the Pressure line, it should read 24/34lbs.
The line running [over] the black canister (fuel filter) is the [return] line from the Pressure Regulator.
Hope this Helps
If you need more help, let me know, I [used] to have a manual guage on mine.
EDIT: Had to add something else
I can always swing by
[This message has been edited by mcgyver (edited April 19, 2001).]
mcgyver is offline   Reply With Quote
Uh, where's the organic produce section again? (cnn link) edkwon Off-Topic 25 06-01-2010 09:23 PM
Where's the Fuel Injector Connector redrex3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-09-2003 01:36 AM
Getting the fuel lines off the Fuel filter t.rod Service & Maintenance 6 02-16-2002 04:07 PM
Where's the fuel pump fuse? subachad Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-18-2001 12:16 AM
HelP, Where's the fuel pump relay? subachad Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-15-2001 04:45 PM
