Old 01-26-2003, 02:01 AM   #1
liigod
Member#: 30512
01 2.5rs
black
Default optima in trunk
so i just got a free optima battery... and MAN is that thing heavy. So i wanted to put it in my trunk, and i ahve an 8 gauge wire in the car... i was wondering if i could run the car off of a 8 gauge wire... i have heard 4 gauge is the way to go, but i have an 8 gauge and would rather not go out and uby a 60 dollar monster wire or something and they are pretty beefy and id ont really have much room for them . Can I run just the car off of the 8 gauge? no system or anything that would be seperate.
thanks
colleen.
liigod is offline   Reply With Quote
Old 01-26-2003, 08:44 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
8 gauge will not be enough to run from the trunk back up to the engine. The OEM starter cable is 4 ga. but that is for a short run of a couple of feet, so if you want to install it in the trunk and have the car start properly, as well as avoid voltage drop for the electrical system, you would have to use the heaviest cable possible. 2 ga. would probably be ok, 0 even better. Also be sure to install it in a proper box with venting to the outside, although Optimas don't normally generate gas they can under some circumstances.
And which one did you get? If it's an equivalent size to the stock battery it should be close in weight. I have a Group 35 Red-top and it weighs about the same as the 35 I took out. If you got a Group 34 then it would be somewhat larger and heavier.
Old 01-26-2003, 03:49 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you need a minimum of 4 guage wire but my personal reccomendation is 2, 0 or 0/2 guage...remember it has to be able to support 200 amps for up to 15 seconds. that's a lot of power flow and a TON of heat. Heat=Resistance
jeremy
Old 01-26-2003, 05:51 PM   #4
liigod
Member#: 30512
01 2.5rs
black
its a red top, it seems to be a tit bit bigger than the previous battery, thanks guys for your help.
Old 01-26-2003, 06:20 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
it's probably a 34 series which is what i have
Old 01-26-2003, 06:53 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That would explain the weight. Since you already have it, and it was free, go ahead and make use of it. If you were just going out to buy one I'd say that the 35 is more than sufficient and weighs many pounds less.
Old 01-27-2003, 03:15 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
not to me, i'd rather add a few pounds and get the 800CCA's from the group 34
Old 01-27-2003, 08:03 AM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Well, if you really want/need the extra power it's the way to go as long as you don't mind the tradeoff in terms of weight.
I've found the 720CCA from the 35 to be plenty even on cold days like we have here today. Anything is better than the 325 in the stocker.
Old 01-27-2003, 12:54 PM   #9
defduane
Member#: 17718
2006 Forester XT
Dark Blue
8 gauge is definitely too small and u don't have to spend a lot on larger gauge wire. Try this place: http://www.knukonceptz.com
defduane is offline   Reply With Quote
Old 01-29-2003, 06:42 PM   #10
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Also, don't forget that you need to be VERY careful how you route it up front. You need multiple layers of electrical insulation and physical protection against chafing, etc. Since there is no fuse on this monster cable, any place along the run from the battery to engine compartment that the insulation wears through and touches the chassis: * Bang - instant carbeque *!
This is one of the main reasons why car makers put the battery right next to where the starter is...
Old 01-29-2003, 08:07 PM   #11
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Most of them, but there are lots of cars with the battery in back and the engine in front (think BMW) and of course there was the old VW with the battery under the seat, and my Renault Dauphine with the battery in front and engine (what little there was) in back.
Alan is offline   Reply With Quote
Old 01-29-2003, 08:11 PM   #12
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yep, I had one of those VWs. An excellent place for a battery, especially when they leaked and rotted out the floor underneath. Sometimes the rot was so bad the battery would just fall out. I was fortunate, mine had only a small hole.
Audi used to put them under the rear seat as well, and Porsches used to have them up front. Not sure if either one still does this.
Old 01-30-2003, 07:52 PM   #13
Suba_Roo
Member#: 5691
2001 2.5 RS
Silverthorn
Go to a welding shop and get 2 gauge cable. The stuff they have is inexpensive and super flexible.
Suba_Roo is offline   Reply With Quote
Old 01-30-2003, 08:44 PM   #14
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Yep, my Miata has it in the trunk, too. The point is, if it's designed in from the start, provision is made to run a monster power cable safely the length of the car; it's a lot trickier to do this properly as an aftermarket mod.
Old 02-08-2003, 09:30 PM   #15
Bimmer
Member#: 4116
2002 Impreza TS
FWIW, I've heard this is a bad idea. AFAIK, welding cable is flexible because the strands of wire are smaller, and this leads to problems in the long run, somehow. You might do a search and see what else's recommended... this topic comes up over and over.
Ben
Bimmer is offline   Reply With Quote
Old 02-09-2003, 01:27 AM   #16
gator
Member#: 18296
2004 STi
WR Blue
Check summit racing or jegs high performance. They usually carry kits for mounting the battery in the trunk along with the various pieces/parts seperately since they sell alot of drag and circle track stuff.
gator is offline   Reply With Quote
MO: Fiberglass sub box to fit in passenger side pocket in trunk clbd39 Interior/Dressup/Audio & Security 11 09-08-2007 09:53 PM
Cheap Optimas in PDX! Flowmastered87GL North West Impreza Club Forum -- NWIC 0 02-06-2005 10:24 PM
('93-'01) ??tube in trunk?? what is it? Accurit Impreza Forum 6 04-10-2001 10:44 PM
Light in ashtray and none in trunk? BOB YOUNG General Forum Archive 2 01-10-2001 01:13 AM
Securing sub box in trunk youthanasia Vancouver Impreza Club Forum -- VIC 1 08-17-2000 02:06 AM
