Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-01-2001, 09:19 AM   #1
IMPREZAmike
Member#: 169
98 black OBS
move bi*ch get out da way
Question What is this noise comming from my clutch? ABS issues too...
I had my clutch replaced about 4-5,000 miles ago, and recently, when i press the clutch in to switch gears or to stop, i get a whiring noise....not really grinding, but borderline.....and man is it annoying. It will continue to make the noise as long as i hold the clutch pedal down. If im at a stop light, i will lift my foot off the clutch and press it back to the floor and the noise goes away....anyone have any ideas?
Also, I have had my car back from the shop for 3 days now (rear ended someone 4 weeks ago) and every once and a while when i go to make a full stop and have my foot on the brake, i get the ABS to react, on dry pavement? Im guessing a sensor is messed up? any ideas on that too would be great!
Thanks!
//m
IMPREZAmike is offline   Reply With Quote
Old 03-01-2001, 09:31 AM   #2
555wagon
Member#: 2809
'00 Moto Guzzi
'91 Talon Rally Car #373
Post
My OBS does the same thing for about 5-10 seconds then the noise stops. Anyone with ideas? I'm thinking TO bearing.
555wagon is offline   Reply With Quote
Old 03-01-2001, 09:40 AM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Maybe your rotors warped which can cause brake pulsations while stepping on brakes. Do you hear that annoying sound when the ABS kicks in?
tmat3 is offline   Reply With Quote
Old 03-01-2001, 04:25 PM   #4
IMPREZAmike
Member#: 169
98 black OBS
Post
I get that repulsive groan when the ABS kicks in...i do need to get my brakes done, so maybe thats the problem....but the clutch? the TO berring was replaced 4000 miles ago also.
hey jerry! whats this noise coming from my car? prometheum Alaskan Impreza Club Forum -- AKIC 13 05-19-2008 09:49 PM
what is this noise my car is making? del105 Brakes, Steering & Suspension 1 02-08-2004 12:27 AM
flapping noise comming from my a.c. yuzo Service & Maintenance 2 07-24-2002 01:40 AM
What is this noise?!?! SoLo OnE Transmission (AT/MT) & Driveline 6 09-14-2001 04:08 PM
