Old 05-01-2001, 01:42 PM   #1
Memnoch
Guest
Member#:
Question Easy/cheap way to remove the rev limiter?
Like the topic says. I'd like to get rid of the rev limiter. That drop in rpms from first to second is finally pissing me off. So if I could rev a bit more like until 6.5k that'd be great. And no I wouldn't be revving more than that, I don't want to start getting valve float.
Anybody know of any cheap or easy way?
Old 05-01-2001, 01:53 PM   #2
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Post
I'm pretty sure there is not one. A replacement ECU is the only way I've found and I am interested in the same thing. I need that extra few seconds in second for Autocross.
skidplatez is offline   Reply With Quote
Old 05-01-2001, 01:58 PM   #3
Blindeye_03
Member#: 4418
2016 Focus ST
Post
Get a 'torque chip' from JC Sports...I think thats who makes it. It adds power and removes the rev limiter (to my knowlege). Its also cheaper than the tec-II. IMO its a good choice over the Tec-II if you are staying N/A.
Blindeye_03 is offline   Reply With Quote
Old 05-01-2001, 02:20 PM   #4
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Post
I wouldn't do it but there should be a wire you can cut to eliminate it.
John2.5RS is offline   Reply With Quote
Old 05-01-2001, 02:39 PM   #5
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
Post
Well if you had a '98RS with a DOHC engine, you could rev to 6500. But unless you upgrade your internals, that limiter isn't just there to annoy you
-Kurt.
Darshu is offline   Reply With Quote
Old 05-01-2001, 08:24 PM   #6
2yLiTe
Member#: 660
Post
Go WOT in 5th until it won't go any faster, then downshift to first...that oughta' get rid of the rev limiter once and for all.
...I couldn't resist. sorry....
"And now back to our regularly scheduled post..."
2yLiTe is offline   Reply With Quote
Old 05-01-2001, 09:57 PM   #7
inpreza kid
Member#: 3334
Post
i think that the jc sports TC2 only removes the speed limiter not the rev limiter.
inpreza kid is offline   Reply With Quote
Old 05-02-2001, 07:09 AM   #8
SuBart
Member#: 2956
06 Sti-white Stg 2
98RS-rally blue
Post
Thats correct the torque chip removes the speed limiter not the redline limiter.
SuBart is offline   Reply With Quote
Old 05-02-2001, 08:10 AM   #9
Memnoch
Guest
Member#:
Post
This is the kind of thing I'm looking for. It's not that I just want to over-rev, and it's not just 300rpms you gain, but a better starting point in second gear as well. The decrease in gearing in those two gears is too much. Anybody else know of anything short of a replacement ECU?
Old 05-02-2001, 09:00 AM   #10
jeffg
Member#: 2958
2001 6.0?RS
Post
I believe the wire you would need to cut is the RPM signal wire from the engine...
The problem being without this signal the ECU will have no idea what the engine is doing and probably not even run.
My opinion learn to drive with the lower RPM or chage gear sets to get the rpms where you need them for whatever speed you want to be at.
Jeff
jeffg is offline   Reply With Quote
Old 05-02-2001, 10:13 AM   #11
Memnoch
Guest
Member#:
Post
Like you said, I would have no tach then. That would be more counterproductive than useful.
And what exactly did you mean by learn to drive in the lower rpm's? I don't have the cash to get a shorter second (when I decided to open the tranny I'll do lots of things at the same time, ie. clutch/flywheel/tranny mounts). Besides my gears are short enough right now, I'm running on 205/45/16's. My only interest in this is getting better accel out of turns for SOLO I where I compete (basically the god damn U-turns).
Old 05-02-2001, 01:27 PM   #12
Darshu
Member#: 1676
98RS w/ EJ257/Dom
Talking
A lighter flywheel will help you rev faster if that's what you're looking for and a better clutch is going to help you get that power to the wheels in a more efficient manner.
If you're looking to get the car to rotate around the U-turns, tires and suspension mods are going to be your best bet though.
-Kurt.
Old 05-02-2001, 01:49 PM   #13
Blindeye_03
Member#: 4418
2016 Focus ST
Post
How high do you have to rev the engine on an incline for you to go forward & not roll back?
Old 05-02-2001, 01:51 PM   #14
Prog
Member#: 1473
2005 Legacy GT 5MT
Satin White Pearl
Post
if you want higher rpms then you shouldve bought a civic si or integra
ROFLMAO
Prog is offline   Reply With Quote
Removing the Rev Limit west_minist Engine Management & Tuning 3 11-06-2004 08:02 PM
Way to remove my rev limiter? subyguy2 Engine Management & Tuning 1 11-07-2002 11:17 AM
What is the best way to remove the clock housing? and tap wires for gauge lighting? NYWRXTASY Interior & Exterior Modification 10 11-03-2002 11:41 AM
Any way to dissconnect the rev limiter? Eric SS Normally Aspirated Powertrain 32 10-08-2001 08:26 PM
how to rasie the rev limit the spacecowboy Normally Aspirated Powertrain 9 04-08-2001 12:03 AM
