Old 05-01-2001, 02:04 PM   #1
Gadget6
Member#: 6239
00 2.5 RS sedan
Silverthorn
Question Backfiring on MY00 2.5RS w/ MT
Has anyone experienced a moderate backfire at the shift point between 1-2 and 2-3 gears? My 2000 2.5RS sedan has done this off and on since new. Frequency of the problem seems to be increasing with age and is more apparent when the engine has warmed up. Dealerships have diagnosed the problem as being everything from "normal for the 2.5 engine" to bad gas and/ or aggressive driving. I have been told repeatedly that the computer diagnostic reads that the engine is operating normally. Any suggestions?
Gadget6 is offline   Reply With Quote
Old 05-01-2001, 02:57 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Post
do you have an after market exaust?
mine does it too but its not stock.. and i like it
Old 05-01-2001, 03:02 PM   #3
S.Damery
Member#: 1770
Post
Unequal length headers
S.Damery is offline   Reply With Quote
Old 05-01-2001, 03:13 PM   #4
Gadget6
Member#: 6239
00 2.5 RS sedan
Silverthorn
Post
Engine and exhaust are completely stock. I have been reluctant to modify anything for fear that the dealer would blame the problem on the mods.
Old 05-01-2001, 04:06 PM   #5
dandbest
Member#: 1885
2015 Evo
Post
My car has been doing this from day one. I now have a cat back exaust and Larrys intake, and it still does it... It has been back to the dealer at least three times, but for whatever reason, they can never get it to happen (which I think is bs cause it happens to me every day) and they never fix it. I am going to change all the gaskets in the exaust from the engine all the way back in the next few weeks, so I'll let everyone know if it works.
Danny
dandbest is offline   Reply With Quote
Old 05-01-2001, 05:58 PM   #6
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
If it is a popping sound and not a loud crack like gunfire you're just getting a completely normal scooby sound. Its excess gas hitting the cat.
-B
Midwayman is offline   Reply With Quote
Old 05-01-2001, 07:28 PM   #7
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Thumbs up
Man, I love that popping and burbling sound that comes out of the RS! I never had it with my stock exhaust, but it occasionally happens with my Stromung. It's more pronounced during start-up and when the engine is cold. I believe this is due to the fact that the ECU is running the engine a bit richer to help warm things up.
If you're getting a loud "bang" backfire-type sound, then something indeed is wrong. If you're getting the occasional "pop" or two when driving and the engine is not warmed up yet, it's perfectly normal. I notice this happens if I shift around 3-3.5k.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 05-02-2001, 07:21 AM   #8
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
Post
i get it to happen if i am coasting in gear then lightly tap on the gas. makes a nice pop, doesn't sound like it's harming anything, but i thought it might of been the gaskets too..changed them and still the same. i think it's the same as it was stock, just more pronounced with the aftermarket exaust.
trojan9x is offline   Reply With Quote
Old 05-02-2001, 08:32 AM   #9
Iron Man
Member#: 4315
2001 RS coupe
silver/custom
Post
i have the scoobysport exhaust system, and i was told before i installed it that i would get a pop or backfire type noise when driving. i soon found out it only happens around 3k rpm......
whats with that? am i running too rich? not enough oxygen? what?
Iron Man is offline   Reply With Quote
Old 05-02-2001, 09:11 AM   #10
Gadget6
Member#: 6239
00 2.5 RS sedan
Silverthorn
Post
Thanks for the feedback. The "backfire" ranges from a slight puff to a pronounced pop that now occurs with enough regularity that passengers comment on it. I can also get it to happen when I let off the accelerator abruptly at higher RPMs. I have never owned a Subaru before but have spoken to many owners (Impreza and Legacy w/ 2.5) who have not experienced this problem (or at least not noticed it). If it is normal and if it is caused by unburnt fuel hitting the CAT, won't that cause early failure of the CAT? Also, why would the frequency increase with age?
Old 05-02-2001, 09:56 AM   #11
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
*shrug*
Its normal is all I can say. Mine does exactly what you said. Its always there, just not as noticable unless you have a aftermarket muffler. (BTW Ive heard mufflers do tend to get louder with age)
Will 02 2.5RS headers fit a MY00 2.5RS swap? 83Rabbit Normally Aspirated Powertrain 3 05-31-2006 09:19 AM
Intermitent Power Loss at all RPMs MY00-2.5RS-MT b5o5m5b Normally Aspirated Powertrain 21 04-25-2005 01:31 AM
Does ecu relearn over Emanage on MY00 2.5rs-t GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-18-2004 05:18 PM
safc 2 on MY00 2.5rs, will it work? billyr2.5 Engine Management & Tuning 11 07-12-2004 04:17 PM
Help - need advice on camber for MY00 2.5RS aussiebrydon Brakes, Steering & Suspension 10 02-17-2002 09:40 PM
