Old 01-26-2003, 10:37 PM   #1
Darkstar
Member#: 5547
BLACK
Question How to disassemble Molex connectors going to the ECU?
I know nothing about these kinds of connectors so I need some help. I need to take one wire out of the Molex connector going to my unichip Harness and put it in the Molex connector going to the ECU. Can the wires be taken out individually? Or do I have to take apart the connector?
I am a newbie at things like this so any help would be appreciated. Thank you.
Darkstar is offline   Reply With Quote
Old 01-26-2003, 11:18 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Unless the connectors are identical types the pins are not interchangeable. The harness connectors used in the car are not true Molex.
It's possible to extract individual pins if you have a lot of patience and a tool that can release the lock tab inside but it's not easy.
If you don't have a plug-and-play harness for what you are installing you will probably have to cut and splice, or tap, the existing wires to the ECU.
Old 01-26-2003, 11:51 PM   #3
Darkstar
Member#: 5547
BLACK
Thank you for your reply mulder. I was told that this is the easiest way to make a MT turboX unichip harness work for a AT. I may just end up selling it and taking a loss. But I will look for a tool that will help and try again.
Old 01-27-2003, 09:56 AM   #4
StuBeck
Member#: 19546
2009 Honda Fit
Is this a normal molex connector like goes into a computer? If so, this link has some info on how to take them out. http://www.virtual-hideout.net/guide...ng/index.shtml
StuBeck is offline   Reply With Quote
Travel to England - How much $$$ is this going to cost? snvin Off-Topic 42 01-31-2007 03:39 PM
1.8 to 2.5- problems going to non-OBDII ECU? beachbum Normally Aspirated Powertrain 8 06-27-2002 11:14 AM
How many of you are going to Merritt for the Rally Challenge Petrie Vancouver Impreza Club Forum -- VIC 49 04-23-2002 06:02 PM
How many of you are going to Derek's wedding? sandy lam Vancouver Impreza Club Forum -- VIC 14 01-14-2001 08:24 PM
