Old 03-01-2001, 01:28 PM   #1
ninetalesnwf
Member#: 3739
85 R30 skylineGT-T
Red/black
Post Why twin Turbos?
what is the benifit for twin turbos, it it less turbo lag at high boost or are you able to get higher HP
thanks
ninetalesnwf is offline   Reply With Quote
Old 03-01-2001, 01:43 PM   #2
DigDug
Member#: 4077
1999 Impreza 2.5RS
Talking
One usually has a smaller turbine, which lets it spool up faster, and when it gets out of its powerband, the second one is generally already spun up and is getting into its powerband. I doubt there is more HP to be had, the smaller one will become a restriction eventually, if you go that high with boost...
DigDug is offline   Reply With Quote
Old 03-01-2001, 01:44 PM   #3
DigDug
Member#: 4077
1999 Impreza 2.5RS
Talking
Oh, and let me clarify that I am talking about a sequential turbo setup, not running them in parallel. I have personally never seen multiple turbos being run in parallel, but who knows? Somebody's probably tried it...
Old 03-01-2001, 01:51 PM   #4
svxtrem
Member#: 1008
2006 STI
Steel Grey Metallic
Post
There have been many examples of small turbos used in parallel (VR-4, 300ZX)- the benefit is that two smaller turbos will spool more quickly than a single large one. Sequential turbos 'should' have the best of both worlds, even faster spool up, with no power loss on top end. If the turbos are sized correctly, there isn't much advantage of a single turbo over two turbos, unless you can arrange things into an even-firing 3 cylinder design. In this case, you can create an extremely efficient pulse design (depending on camshaft overlap) to drive the turbine.
svxtrem is offline   Reply With Quote
Old 03-01-2001, 01:55 PM   #5
DigDug
Member#: 4077
1999 Impreza 2.5RS
Lightbulb
Hmmm, I always thought the 300ZX was a sequential turbo setup....
Old 03-01-2001, 01:59 PM   #6
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Post
actually... most dual turbo setups are parallel... I believe, the supra twin turbo (maybe, I've heard it is and heard it isn't) and the RX-7 were the only sequential setups that were somewhat widely available. you get two small turbos to spin up faster, so you get less lag, and at higher rpm, you have two turbos, so you should be able to get good boost, even tho they are, on their own, out of their range...
the only benefit I can see of single turbo setups over duals, is simplicity, which can add other benefits as well(lighter, less parasitic loss, etc)
mrbell is offline   Reply With Quote
Old 03-01-2001, 02:03 PM   #7
pbnj9786
Member#: 4473
MY10 STi
Plasma Blue Pearl
Post
Porsche uses the sequential setup as well, and as everyone here knows, Subaru shares the same engine design with Porsche. Personally i wouldnt mind seeing a Legacy twin turbo. or better yet a wrx twin turbo.
pbnj9786 is offline   Reply With Quote
Old 03-01-2001, 02:09 PM   #8
DigDug
Member#: 4077
1999 Impreza 2.5RS
Talking
There is a twin-turbo Legacy in Japan, and it is a sequential setup. I was actually looking into importing one and dropping it in my 2.5RS about a year ago. Freight charges alone were scary...
Though Porsche and Subaru both use boxer engines, I do believe the Porsche engines are a little better engineered!
Old 03-01-2001, 02:20 PM   #9
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Post
Bigger question: why NOT twin turbos?
blaster88 is offline   Reply With Quote
Old 03-01-2001, 02:25 PM   #10
pbnj9786
Member#: 4473
MY10 STi
Plasma Blue Pearl
Post
Well, in the imprezas, i dont think there is room for and the necessary header tubing and the turbos of course.
Old 03-01-2001, 02:45 PM   #11
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Post
blaster88: Why not parallel or why not sequential twin turbos?
I would think the main reason for parallel twin turbos is so you can drive one turbo from each side of a "V" engine. Seems like a pretty convenient setup.
If you were to parallel twin turbo an inline engine, it probably gets more complicated to route separate headers down for each turbo.
So then why not twin parallel turbos in the Impreza, right?
One reason I could think of is that if you have a turbo for each pair of cylinders, then each turbo is only getting power half the time since the engine is a four stroke. So you have two half-powered turbos now, and you're probably not netting any gain.
iodine23 is offline   Reply With Quote
Old 03-01-2001, 02:46 PM   #12
jeffg
Member#: 2958
2001 WRX (GC8)
Post
I noticed that the SYMS catelog has a header setup for twin turbo in a legacy. It looked really nice.
jeffg is offline   Reply With Quote
Old 03-01-2001, 07:25 PM   #13
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Post
yeah, I forgot to mention the porsche, but I didn't know there was a sequential legacy... interesting...
Old 03-01-2001, 10:16 PM   #14
brendon
Member#: 3618
Post
if you are looking for minimal lag and much boost get the aerocharger. they are about 2300$ for the one that fits ej25. what a slick set up no waste gate but variable vane settings hmmmmmm. smooth
brendon is offline   Reply With Quote
Old 03-01-2001, 10:34 PM   #15
Hucker
Member#: 1272
Post
Those areochargers are used alot on Harley's etc. Watched a show on Speedvision about them....
Hucker is offline   Reply With Quote
Old 03-01-2001, 11:17 PM   #16
Adrian128
Member#: 3346
Post
The Legacy twin turbo is a sequential set up, and the EJ20T from an Legacy has been put in a RHD WRX, with mixed results.
Also.. there are a few inline engines with parallel turbo set ups.. Nissan RB26DETT for one, and the Supra TT engines both have twin turbo set ups.
Adrian128 is offline   Reply With Quote
Old 03-02-2001, 01:03 AM   #17
MikeYOX
Member#: 1754
2002 S4
Nogaro Blue
Post
Actually Porsche uses twin identical turbochargers that operate parallel eachother.
MikeYOX is offline   Reply With Quote
FS/FT 1997 VR4 Vacuum Leak $6,500 Twin Turbo Twin Intercooler Meat9834 Private Vehicle 'For Sale' Classifieds 14 01-04-2010 05:49 PM
Twin Turbo and Twin Supercharged Nissan GT-R bend_bugeye Non-Subaru News & Rumors 14 10-15-2009 07:36 PM
Twin Engine, Twin Turbo, 626WHP, 1997 Tiburon, 10.92 1/4 mile on STREET tires alien_sporez Private Vehicle 'For Sale' Classifieds 3 05-04-2008 12:49 AM
What company's offer twin scroll twin turbo kits for the sti? GT42r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 09-12-2007 10:27 AM
Will the twin turbo EJ20 fit 91-94 Legacy turbo? jwooman Legacy Forum 5 05-02-2001 12:26 AM
