Old 04-19-2001, 08:12 AM   #1
cvalle-sd
Member#: 420
2001 Cr-V
Question Open Diff / viscous AWD question
If you lift a rear wheel in the open-diffed pre-00RS (or any), does that free-spinning wheel trigger the AWD to send torque up front, or are you just floating?
cvalle-sd is offline   Reply With Quote
Old 04-19-2001, 08:29 AM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
The center viscous coupler doesn't react instantly, but let's say it was off the ground for ... 3 seconds or so, under power. (probably impossible, I know.) It would limit slip then, yes.
Peg-legging is not a desireable thing-- you can probably corner faster if you tune the suspension so that all four wheels stay on the ground even while braking and turning.
ColinL is offline   Reply With Quote
Old 04-19-2001, 09:16 AM   #3
cvalle-sd
Member#: 420
2001 Cr-V
Post
I've only noticed a spinning rear on a particular 90deg off-camber right hander - in the wet (Friars Rd eastbound onto 15n on-ramp)- but I was still curious. I could use a cheap rear lsd...ahh, Santa.
Old 04-19-2001, 11:31 PM   #4
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Exclamation
On an RS w/o Rear LSD, the rear open diff will eat up the difference between the left and right rear wheels, effectively creating a difference between the front and rear, which will cause the center LSD to lock. With a rear LSD, it will lock up first before the center, and the center will only lock up if both rear wheels are free-spinning.
kgb is offline   Reply With Quote
open diff question speedyHAM Transmission (AT/MT) & Driveline 1 10-12-2007 09:23 AM
05 rs open diff to lsd axle question.. HaPpilyObsessed#44 Transmission (AT/MT) & Driveline 3 02-28-2007 06:27 PM
WRX AWD Rear Diff Torque Transfer Question Mind Transmission (AT/MT) & Driveline 17 01-27-2007 04:38 PM
WRX rear diff viscous or not? petrol Transmission (AT/MT) & Driveline 60 08-06-2003 07:19 PM
ADV/DISADV of center diff, Viscous or Electronically controlled? Garvinator Normally Aspirated Powertrain 1 02-05-2001 04:20 PM
