Old 01-27-2003, 10:05 AM   #1
jaybaroo
Member#: 11149
2000 Outback Sport
Blue Ridge Pearl
Default Coil Question
Does anybody know if the stock coil output is infinately variable, or stepped? I'm trying to figure out a misfire problem...
Thanks,
Jay
jaybaroo is offline   Reply With Quote
Old 01-27-2003, 11:11 AM   #2
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Not for sure, but I could see the stock ecu varying the output based on dwell time. I dont know if it does though.
Sorry I cant help. Free bump for ya though.
-Chav
Chav is offline   Reply With Quote
Old 01-28-2003, 02:01 PM   #3
jaybaroo
Member#: 11149
2000 Outback Sport
Blue Ridge Pearl
Thanks anyway, Chav.. I'm trying to figure out why I'm getting a misfire at low RPM's under medium-to-heavy accelleration, but not at high RPM...
If the coil is stepped, therefore pushing higher current throughout a set RPM range, then I most likely have a coil problem. If not, then I'll look elsewhere for the culprit...
Any suggestions would be helpful...
jay
Old 01-30-2003, 03:46 PM   #4
jaybaroo
Member#: 11149
2000 Outback Sport
Blue Ridge Pearl
Come on, there has GOT to be someone that has the tech knowledge for this in here!
Anyone??
Old 01-30-2003, 05:42 PM   #5
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
I'm no expert but I was under the impression that the current should be relatively constant (linear). If you're getting a midrange hesitation/misfire it could be several things other than a coil problem. What is your AFR, are you running pig rich (which n/a EJs are notorious for). Are you running too lean, detonating and having timing retarted by the ECU? What is the gap on your plugs? What is the condition of your plugs? Is there any sign of arcing either from the coil or from a wire(s)? Do you have any deposits on the coil terminals? BTW, the coils from 99+ (non-EJ20) are known to go out for no apparent reason... one of the many subaru quirks.
coil question capitalj4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-24-2007 10:15 PM
coil question kenneth.bricker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-04-2007 08:51 PM
tanabe sustek pro-SS coil question! domestic_abuser Brakes, Steering & Suspension 2 10-31-2006 12:34 PM
Coil Question. Brupp Normally Aspirated Powertrain 1 02-06-2006 09:16 AM
Coil Questions for 2.5RS #522 Normally Aspirated Powertrain 6 09-22-2002 12:49 PM
