Old 05-02-2001, 01:16 AM   #1
jacktam1
Member#: 1783
2000 2.5RS
Question pressure riser
i'm getting vortech FPR from JCSport,who has the Pressure riser with MY00+, useful?and what's your setting?
Thanks
[This message has been edited by jacktam1 (edited May 02, 2001).]
jacktam1 is offline   Reply With Quote
Old 05-02-2001, 05:02 PM   #2
jacktam1
Member#: 1783
2000 2.5RS
Post
bump..anyone?
Old 05-02-2001, 05:07 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Post
This has been hotly debated in the past( search archives). But my general take on it is on a car that already runs rich with mods, what's the point? Unless you get a rising rate one that kicks in above 4500 rpm where the MY00+'s(at least some of them, this has been hotly debated as well) lean out a bit.
Old 05-02-2001, 07:03 PM   #4
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Post
Not sure of what use this would be on an NA car.
The Vortech FMU, from the Vortech website, "Increases fuel pressure in proportion to boost pressure." It has a hose that connects to manifold pressure, and when it sees positive pressure, it increases the fuel pressure at a fixed proportion (if you got it from JCS it is probably a 4:1) to boost. Installed in an NA car, it won't do anything.
blaster88 is offline   Reply With Quote
Old 05-02-2001, 07:49 PM   #5
jacktam1
Member#: 1783
2000 2.5RS
Post
OIC..so that one is non-adjustable?and 4:1 boost=how much psi?
Old 05-02-2001, 07:52 PM   #6
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Post
I think it is 1 psi boost = 4 lbs fuel pressure. So at 5lbs of boost, you get an additional 20 psi of fuel pressure.
Someone will correct me if I am wrong, I am sure.
Looking for Directions for Fuel Pressure Riser. yebokmj Normally Aspirated Powertrain 1 03-05-2001 09:47 AM
Suggestions on Fule Pressure Riser J Colman General Forum Archive 2 12-20-2000 12:39 AM
Is a pressure riser a worthwhile mod? Matt Monson General Forum Archive 2 11-10-2000 06:19 PM
Weapon R Fuel Pressure Riser and Icon skywalker Bay Area Impreza Club Forum -- BAIC 0 08-21-2000 03:55 PM
Super AFC vs Fuel Pressure Riser (must read) Xscreamer Technical Forum Archive 2 05-16-2000 05:50 AM
Message Board Statistics All times are GMT -4. The time now is 07:57 PM.
