Old 01-27-2003, 02:34 PM   #1
NimrodBoz
Member#: 18500
2005 OBS
Question Electronic whine
I have a friend who owns a 2003 forrester 2.5 XS and the car is making a high pitched whining noise when the engine is off...signifying an electrical problem maybe? After being left cold all night the noise was still there in the morning. It is porbably nothing to do with the radiator pressure and cannot have to do with the vacuum. It was nearly 0 degrees farenheit over night.
Any help would be greatly appreciated.
NimrodBoz is offline   Reply With Quote
Old 01-27-2003, 05:02 PM   #2
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
I'd also make a whining noise if I got left out in the cold.
Any idea of where it is coming from? Engine area? Inside? Alarm horn? Radio speakers? Could even be something like locks trying to lock or unlock a frozen latch, or wiper motors. So try and locate where the noise is loudest.
Alan is offline   Reply With Quote
Old 01-27-2003, 05:35 PM   #3
NimrodBoz
Member#: 18500
2005 OBS
Default Wheres it from?
It is loudest when your ear is right at the grill near the front emblem, and it is coming form the engine bay. it is loud and high pitched and annoying no less. considering that the motor was off all night it couldnt be a mechanical noise, must be something electreonic. we speculated maybe the radiator was losing pressure but its fine so....????
Old 01-27-2003, 05:47 PM   #4
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Sounds like it might be the alarm horn. Which could be caused by something weird in the security system. If you have that installed. I'm not sure where the alarm hhorn is on the Forester, but it's in the engine compartment somewhere.
Otherwise it could be a frozen fan motor, though why it would be on in the cold is beyond me.
Take it in to the dealer, whatever it is it'll be covered under warranty. And hope it stays cold if that's what is causing the problem.
Old 01-27-2003, 06:03 PM   #5
NimrodBoz
Member#: 18500
2005 OBS
the sound was actually coming from something near the horn but it wasnt the usual horn sound (obviously). thanks, we'll get it checked out. later today we didnt hear the noise when i met up with him but ill see whats going on tomorrow.
thanks
Old 01-28-2003, 07:53 PM   #6
NimrodBoz
Member#: 18500
2005 OBS
does anyone else have any takes on this? i really am kinda clueless as to what may cause the whine. ill check on his horn to see if thats doing it...
Old 01-18-2011, 11:42 PM   #7
04works
Member#: 91493
2006 STi
sorry to bring back from so long ago, but this is th exact issue im having. i sounds like its from the radiator fan/hood release area? the car hasnt been started in hours. when i jiggle the hoos release, th enoise comes and goes? any ideas? didn't want to start another thread. thanks!
04works is offline   Reply With Quote
Old 02-17-2012, 01:38 AM   #8
Bobert540
Member#: 82281
2013 WRX Ltd. Hatch
I am having this same issue. Just started and cant figure out where its coming from. Seems like its near radiator cap area but the sound is very high pitched like an electrical issue.
Bobert540 is offline   Reply With Quote
Old 02-18-2012, 05:19 AM   #9
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
To see if the problem is due to pressure in the radiator remove the pressure cap as long as the coolant isn't hot. If the sound goes away then you found the source of the noise. If that doesn't help then disconnect the negative battery lead briefly to see if that changes things.
Old 02-18-2012, 05:26 AM   #10
spidercat
Member#: 288449
pull the leads off of the horn pack them with grease reattatch I has the same buzz/whine worked for me
spidercat is offline   Reply With Quote
I want to hear the turbo- whining about whine downwind4final Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 10-02-2006 10:51 PM
[Whine]I'm never going to find a good car[/whine] BigWrecKs Off-Topic 51 07-04-2006 03:25 AM
[Whine]I'm never going to find a good mod[/whine] BacDoc Off-Topic 21 07-03-2006 06:41 PM
What's worse? Whining women or whining Georgethefierce? imprezton Off-Topic 17 09-28-2005 02:33 PM
Help me ID a noise: Electronic sounding whine treybomb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-18-2003 12:36 PM
