Old 01-27-2003, 05:19 PM   #1
virus67
Member#: 7615
2002 Imreza WRX
Midnight Black
Exclamation One Hell of a Boost Spike
I had some problems with my turbo xs dual stage boost controller so i hooked the factory one back in and figured while i was at it do this mod http://www.scoobymods.com/forums/sh...hp?threadid=542 (replace the restictive hoses) and it started boostnig right again but now its spiking hardcore in 2nd/3rd gear at WOT, talking like 1.7bar! 1st gear stays at .5 constant then it 2nd is out of control, heres a pic of the way i installed it, are my hoses 2 short?
http://v1rus67.freewebspace.com/images/DSC02630.JPG
note: you might have to copy and paste the link in a new window if it says something about remote linking
virus67 is offline   Reply With Quote
Old 01-27-2003, 10:07 PM   #2
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
? don't have the original hose with the brass restrictor IN it ?
The description sounds like the Factory Foost Controller (FBC) is almost being slow to react...
how does the white coupler compare to the original restrictor?
If it is smaller it would be similar in effect to the 3/16" mod...
The ecu needs to learn, but just a waver not spiking though...
If the FBC were gone (just a hose from turbo to waste gate) then you should only see waste gate spring preasure...
Is you waste gate actuator bad???
Scooby mods is down so I have no idea what you are trying to accomplish...
Return it to stock lines & control & start over???
GLwagon is offline   Reply With Quote
Old 01-28-2003, 07:36 AM   #3
virus67
Member#: 7615
2002 Imreza WRX
Midnight Black
thanks for the info, unfortunately the reason im going back to stock is because my previus turboxs dual stage boost controller went bad on me and i had to return to the stock one, but the stock hoses are no longer in my possession so i bought a 3/16" vaccum restrictor and plugged it in between the turbo port and the t-connecter as you can see. I might try resetting the ecu to see if i can speed up the relearn... but its funny, i seem to be boosting much more on the stock boost controller then i was with my old manual one, even when it was working .
Old 01-28-2003, 11:58 AM   #4
virus67
Member#: 7615
2002 Imreza WRX
Midnight Black
Ok, heres specifically whats goin on, its going to .5bar then steadying out for a bit, then it joltz really fast to like 1.7, back to .5 then back to 1.7 over and over, it feels like the stock boost controller is lagging as smoene was saying. what should i do?
Old 01-28-2003, 05:26 PM   #5
virus67
Member#: 7615
2002 Imreza WRX
Midnight Black
that coupler is a 3/16" coupler with a restrictor built in it, all the new hoses are 5/32" because the store here doesnt sell 3/16", but it should be close enough.
Old 01-28-2003, 06:01 PM   #6
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
Originally posted by virus67
that coupler is a 3/16" coupler with a restrictor built in it...
Some one makes such a thing???
how small is the hole in the coupler...
I'm betting it is too small, try a regular 3/16 coupler that should stick you at .5 bar max...
do some searches on the brass restrictor somone listed the hole diameter...
?have a local dealer... all the parts should cost around $10-15
Old 01-28-2003, 07:42 PM   #7
virus67
Member#: 7615
2002 Imreza WRX
Midnight Black
k, thanks for the info, i did some searches but people mainly ended up solving their problems by replacing their factory hoses, which i dont have, i think ill head to subaru and grab em as you suggested. Thanks again for your help.
One hell of a mom. cloudbase Off-Topic 25 05-02-2007 05:17 PM
this is one hell of a model ridestreet84 Alaskan Impreza Club Forum -- AKIC 11 02-21-2007 04:54 PM
Today is goin to be one HELL of a day... ima5exyindo Off-Topic 4 08-15-2005 10:38 AM
Better be ONE HELL of a movie... WRXGuyInUSA Off-Topic 19 06-28-2004 09:33 AM
one hell of a cop! spunky General Forum Archive 2 10-24-2000 11:35 PM
