Old 03-01-2001, 08:03 PM   #1
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Post HELP!, installing shift light
I have a Autometer Shiftlight, I need to tap into the tach wire. anyone know where the heck this thing is?......any suggestions from anyone who has done a tach or shiftlight install would be greatly appreciated.
thanks
Aaron
01 Impreza R.S.
Deity is offline   Reply With Quote
Old 03-01-2001, 09:18 PM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Post
its the middle wire its is yellow/blck stripe
the wire can be found on the black square on top of your engine intake manifold.(where the spark plug wires connect)
fill free to pm me; will be glad to help.
steven
also mounted mine in a awesome place where no holes in your dash.
AliBenn is offline   Reply With Quote
Old 03-02-2001, 07:19 AM   #3
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Post
must be different between our model years.The plug going to that box has four wires....first one is green/red next is green and the next 2 are blue from what I can see. according to some car stereo documentation on my car the green/red wire is the tach wire.....is this one I want to tap into?..or do I need a negative?
Aaron
Old 03-02-2001, 10:41 PM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
If you are tapping in at the ECU then it is Pin #30 on Plug B134 which is the left most plug on the three plug harness...
See www.lagging.com for the ECU pinouts.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 03-03-2001, 12:33 AM   #5
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Post
BUMP
Old 03-04-2001, 03:37 PM   #6
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Post
I got the light hooked up....but the RPM module only seems to be working at like twice what its supposed to...
the light works...but the included 3000 RPM module only activates the light at like 5500 RPM....
thats messed up....I remember someone saying somthying about tachs having to be recalibrated for our cars..I wonder if this would be the same issue?
Aaron
Old 03-04-2001, 03:37 PM   #7
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Post
BUMP
Old 03-04-2001, 10:34 PM   #8
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
Post
Deity, i have an autometer shift lite as well. Make sure u select 4 cylinder in the back of the module. if u select 6 or 8 the rpm's will be off =)
Orbiter is offline   Reply With Quote
Old 03-05-2001, 07:19 AM   #9
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Post
Yeah I selected 4....it still does not work right..I suppose I need to call autometer.
just out of curiosity where did you tap into...the ECU or at the coil?..and what wire was it?
Thanks
Aaron
01 Impreza
Old 03-05-2001, 08:52 AM   #10
Aspen
Member#: 145
Banned to
Housework for Summer
Post
If you have other rpm pills, you might want to try them(if they're lower).
I had the same problem with the Summit Racing RPM activated switch. It had a 4 cylinder setting but it was still activating at twice the rpm. I just ended up dividing the redline by two.
Aspen is offline   Reply With Quote
Old 03-06-2001, 07:05 AM   #11
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Post
FINALLY!!
finally we got it to work last night. I would like to thank everyone who gave advise and help to me.
Thanks a bunch
Aaron
Old 03-07-2001, 07:22 AM   #12
AWDrivin
Member#: 1687
99 2.5RS
Thumbs up
Congrats on getting it to work! But it would be helpful if you let us know the details after all was said and done, what made the difference?
Chuck b
AWDrivin is offline   Reply With Quote
Old 03-08-2001, 09:01 AM   #13
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Post
Sure,
I had talked to several people who had hooked tachs and such up at the ignition coils. Which seemed right to me. We tried that and the light would only activate at twice the RPM of what it was supposed to. Other people had hooked up to the tach output on the ECU, I was very reluctant to even look at that thing so we tried the coil wire first. After speaking with Autometer they said because my car had dual coils it was only recieving half the pulses it would normally from a single coil 4 cyl. He also said if I sent it in they could recalibrate it to work on half the pulses. Well before I went to that extreme We went ahead and hooked up to the tach output (with the help of several people like larry and orbiter helping me locate it on the ECU) and then perfecto!....we went ahead and hardwired it and installed it and the rest is history. Also, sorry to tell you gasser, if you had hooked to the ECU you wouldnt have had to send your tach in to be reset either....live and learn I guess....our mistakes will help others though
thats how it went, thanks again to everyone who helped me.
Aaron
01 Impreza R.S.
Old 03-08-2001, 09:03 AM   #14
bratmantlz
Member#: 3231
88 626 Turbo
white
Question
any pics of this thing eh?
bratmantlz is offline   Reply With Quote
Old 03-09-2001, 02:38 PM   #15
Deity
Member#: 3443
0102 2.5 RS & WRX
STM and PSM
Post
I have some pics of it, unfortunatly none of it installed, I will try to get some though
Aaron
installing shift light...what wire to tap? JasonLI25T Electrical & Lighting 4 06-13-2010 08:16 AM
How to Install Shift light/chime in a WRX Jstyles21 Electrical & Lighting 5 12-29-2007 02:58 AM
need help installing shift light d's_wrx Newbies & FAQs 0 07-24-2002 05:13 PM
installing shift light pro2cer604 Vancouver Impreza Club Forum -- VIC 3 01-06-2002 12:21 AM
need help installing shift light GimmeScoobySnacks Interior & Exterior Modification 5 04-05-2001 07:41 AM
