#1 |
Member#: 10254
RMIC
Vehicle:1995 Impreza Rally red with 2.0L turbo motor |
Building a EJ22 that is open deck N/a right now.
I got a great deal on it but it has the stock pistons and rods. I could turbo it as it sits and run like 8-9 psi of boost on stock compresion. or i was thinking of getting lower compresion pistons and stronger rods and running like 15-20 psi and really build the motor up. what do you guys think i should do. I plan on building the motor over the next 1 and a half so money is almost no option. I do want the car to be daily drivable but want to build it to handle SM auto cross classification. thanks, Erik S.
#2 |
Moderator Member#: 922
Vehicle:04 FXT Red |
If you want to stick with 2.2L, get yourself a 2.2 turbo legacy motor from a dealership. The shortblock should only be $1100-1200 and will have low compression pistons, oil squirters, and would be closed deck already. Probably capable of 15-18psi out of the box. The question would be, what type of boost/flow can your heads handle. You may need work there.
#3 |
Sooby Guru
Member#: 1914
SWIC
Vehicle:2000 2.5RS w/ EJ22T swap and N20. gone. : ( |
DannyRS has a lot of experience with the EJ22T and running high boost. He should be able to give yo usome good info.
Eric |
#4 |
Member#: 145
Vehicle: Banned to Housework for Summer |
I agree with getting the EJ22t shortblock if you plan on building your motor. I don't think you can close deck your block and get lower compression pistons and better internals for under $1k which is what a brand new EJ22t shortblock costs.
If it was me, I would just run the EJ22 as it sits until you blow something, then go for the gusto... I will most likely push the envelopes of the NA 2.2L motor when I'm ready to swap in my jdm motor in the spring or summer. |
#5 |
Gone... But not forgotten
Member#: 13082
I don't want to hijack the post, but I've got a question about EJ22T motor.
Does the WHOLE motor cost around $1000 or only the block with crank, pistons, rods , heads ? If it's the block, can EJ25 heads be put on it ? What computer should one use to manage this engine (legacy ecu + piggy backs or standalone) ? Is wiring as difficult as swapping EJ20T or simpler ? Thanks ![]() |
#6 |
We're talking about a short block, which is block assembled with crank, rods, pistons, and associated rings & bearings. Yes, your heads should bolt up just fine.
#7 | |
Sooby Guru
Member#: 1914
SWIC
The only extras I had to buy other than the short block was new headbolts and new head gaskets. Eric |
| Thread Tools | |
| Display Modes | |
| OT: What to do for the next hour or so? | Prod | Off-Topic | 7 | 03-05-2006 11:57 PM |
| What to do for maximum acceleration and/or traction.... | DilferJr | General Community | 13 | 01-26-2006 10:36 PM |
| Stuck..I don't know what to do... Bigger N/A Motor or 1.8 Turbo | jedz123 | Subaru Conversions | 13 | 09-24-2004 10:55 AM |
| What to do? Sell car buy newer or upgrade car now. | stentorian | General Community | 15 | 06-09-2004 11:01 AM |
