Old 04-19-2001, 11:47 PM   #1
oldpreza
Member#: 5259
1995 Impreza
Post How do I fix a RS shifter into 95 L?
Seen a couple of dead posts about fixing a RS shifter to earlier L models. Not much said there. Hopefully someone can guide me on what I need in order to install a RS shifter into my 95 L.
And is the RS shifter shorter than my stock shifter? I find that when i handle my gear lower on the shaft, the gear box isn't as grouchy.
oldpreza is offline   Reply With Quote
Old 04-20-2001, 11:41 AM   #2
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
I will tell you by next weekend, My GF just got a 98 L coupe, Im giving her my old RS shifter if it is any different. If they are interchangeable, all you have to do is follow the directions in the MODs section to swap one in for the other. It took me 15 minutes to swap standard RS for COBB short shift.....real easy.
STiShawn is offline   Reply With Quote
Old 04-20-2001, 03:57 PM   #3
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Thumbs up
I Don't know if it means anything, but I put a MY00 RS shifter in my '97 Legacy Outback a few weeks ago. I suspect that the basic linkage is the same on all relatively new Subies...
Doug
dvancleve is offline   Reply With Quote
Old 04-20-2001, 04:39 PM   #4
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Post
The linkages changed in 97.
Here's an old post:
http://www.i-club.com/ubb-files/Arch...15-003212.html
I ended up having to replace the complete linkage with an RS one. What a PITA. Let me just say that you are not going to want to do that. I would go for the Graham Goode one, it'll probably run about $150.
redobs is offline   Reply With Quote
What is this, how did I break it, and how do I fix it? XanRules Transmission (AT/MT) & Driveline 12 08-20-2009 08:53 AM
HELP! What is this? How did it happen? How do I fix it? MyFirstDeuce Transmission (AT/MT) & Driveline 5 09-24-2006 10:50 PM
RS shifter into Outback dvancleve Legacy Forum 0 04-10-2001 09:15 PM
How do I fix this? Impreza Rider Mid Atlantic Impreza Club -- MAIC 2 04-10-2001 05:10 AM
My RS doesn't rattle like my buddies, how do I fix that? Rez General Forum Archive 12 12-22-2000 12:28 AM
