Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 01-27-2003, 09:27 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default electrical problem
I'm guessing this will be hard to diagnose and i need to take it somewhere but maybe you guys can help me out. My car has been taking a long time to start up in the mornings in the cold. I thought the battery was just getting old, so i replaced it. Its still hard to start and now i've noticed some other problems. When stopped at a light at night with headlights and heat on, the fans on the heat will slow down noticeably and the headlights and interior lights dim considerably. If i give it gas, the lights immediatly get brighter. I've also noticed the clock will get dimmer when the blinkers are turned on. Any suggestions as to what would be causing this?
lotusTT is offline   Reply With Quote
Old 01-28-2003, 09:25 AM   #2
pdximpreza
Member#: 17606
2002 Impreza 2.5RS
Possibly alternator or voltage regulator. Though I think both are in the same unit now.
pdximpreza is offline   Reply With Quote
Old 01-28-2003, 10:35 AM   #3
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
If the battery is fully charged it should start the car well even if the alternator was sick, so I suspect bad connections. Check the ground connection to the engine and chassis, as well as the battery terminals.
If you have a voltmeter you can check grounding easily by turning on the lights and reading between the battery post and the chassis - there should be little or no voltage.
Alan is offline   Reply With Quote
Old 01-28-2003, 10:50 AM   #4
tdxflex
Member#: 13634
get your alternator checked out and see how many amps it's putting out. should be close to 75, but it doesn't sound like it since your electrical system is dimming and it's all factory wiring. one of my friends bought a 130amp alternator for his car, had similar problems and had it tested. it was only putting out 11amps! should be covered under warranty if that is the problem
tdxflex is offline   Reply With Quote
Old 02-07-2003, 05:28 PM   #5
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
I have this same problem on my Maxima.. It's worse now.. the alternator was a rebuilt.. Maybe this is why it looks like I'm driving without any headlights on now..
SubaruImpreza_power is offline   Reply With Quote
Old 02-07-2003, 06:45 PM   #6
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
I'm going to say look at your wires. Look at the wires at the battery. Look at them at the starter. Look at them at the alternator. Look at the engine-to-chassis ground strap.
If they're all fine take it to a Schuck's and have them test your electrical system. If the battery is fully charged and you don't have a problem starting, but after a while it comes back, then replace your alternator/voltage regulator. Always replace the regulator if you replace the alt. if they're not integrated (like on my truck, the VR is on the firewall).
Make sure your terminals are clean and tight so there's good contact.
CosmoTheCat is offline   Reply With Quote
('93-'01) Help!! Legacy Electrical Problems mhj Impreza Forum 4 07-26-2001 07:32 PM
('93-'01) Please help - Electrical problems Boeleni Impreza Forum 2 04-08-2001 08:53 AM
Electrical problems? Bohanan Texas Impreza Club Forum -- TXIC 6 12-24-2000 05:18 PM
Static electricity problem dead-eye General Forum Archive 36 12-08-2000 09:40 PM
Weird electrical problem JJTheSubeDriver Car Audio, Video & Security 4 01-28-2000 08:23 PM
