Old 03-01-2001, 08:13 PM   #1
Blindeye_03
Member#: 4418
2016 Focus ST
Post ram air
Where can I find a ram air intake at online. I heard that prodrive makes one but I cant find it anywhere.
Blindeye_03 is offline   Reply With Quote
Old 03-01-2001, 09:08 PM   #2
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
well do a search in this forum it has been brought up alot. some one has it i forgot who though good luck
bratmantlz is offline   Reply With Quote
Old 03-01-2001, 10:39 PM   #3
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
Pontiac has "Ram Air V6" emblems on the GranDamns. I laughed so much I missed 3rd gear. Unless the "ram air" is coming from behind the radiator, I don't know how it works. There are no hood scoops.
CosmoTheCat is offline   Reply With Quote
Old 03-01-2001, 10:43 PM   #4
Hucker
Member#: 1272
Post
horatio102: Open the hood and check for yourself. The "ram air" intake is right about the rad. So yeah, the GrandAm GT's are ram air...
Just thought you might want to know.
Hucker is offline   Reply With Quote
Old 03-01-2001, 10:54 PM   #5
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Post
I have a friend with a Ram Air GrandAm GT. Yup, right above the radiator, and it give a whopping 5 HP increase over stock! Oh, well, like I always say, every horsie counts! It's a nice car.
HondaH8er is offline   Reply With Quote
Old 03-01-2001, 11:58 PM   #6
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Post
At what? 150 mph?
Impreza Rider is offline   Reply With Quote
Old 03-02-2001, 04:58 AM   #7
Blindeye_03
Member#: 4418
2016 Focus ST
Post
Well the imprezza has a hood scoop and I intend to use it...How do I search the forums...I am new here!!
All I want to know is WHERE to get one.....
Old 03-02-2001, 05:08 AM   #8
hacman
Member#: 3603
Post
go back up to the top of this topic. See on the right, it says Post Reply? right underneath it.
this link might work too, I'm not sure:
here
The ram air setup has been beaten to death in this forum.
hacman is offline   Reply With Quote
Old 03-02-2001, 05:34 AM   #9
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Post
Blindeye_03,
I use a MRT WRX bonnet hood scoop for ram-air. Check my the member's pic section to see it or check out MRT's website and search for wrx bonnet hood scoop. It raised my 1/4 mile mph by 1-2mph but I don't know how much extra horses were made if any.
Kevin Thomas is offline   Reply With Quote
Old 03-02-2001, 09:19 AM   #10
wackit
Member#: 3200
2000 Impreza RS
BRP **RIP**
Post
I had my car shop "Griffin Motorwerk in Berkeley" Make me a custom ram air intake. U know the little orange vents at the bottom front end of the car... well on the passenger side i had the vent removed and put a noeprine tube in where that little orange vent used to be. the tube runs from there to the stock pletum that i still use with the stock filter. works grate the only worry i have is going throught big puddles but even in the rain i have had no prolbems for the past 16k. I change my air filter a little more often because it seems to get dirty faster but that it.
wackit is offline   Reply With Quote
Old 03-02-2001, 09:24 AM   #11
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Post
The only person who I knew who had a Ram Air set-up was "Dan" with his 99' RS. I just deleted the link in my favorites because I hadn't gone there in a while. I don't remember his full name or web-address.
But his car was Blue, with dark tints and Chrome Rims if that helps.
BrysImpreza is offline   Reply With Quote
Old 03-02-2001, 09:37 AM   #12
bratmantlz
Member#: 3231
88 626 Turbo
white
Question
are you talking about the hood vents beeing converted to hood scoops? i saw those once and am saving for em they are sweet!
Old 03-02-2001, 09:43 AM   #13
Frank
Member#: 3791
Post
If you wanna put your hood scoop to good use and get some forced air into the engine get a turbo. Ram air will give you like .8 psi. Why mess around, save your money and get the blower.
~Frank
Frank is offline   Reply With Quote
Old 03-02-2001, 09:57 AM   #14
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Post
I've done something very similar...but different!
Anyway...I am going to be working on this over the weekend, so I will post more as it comes up.
....OK, so I don't want to work right now...
here is a picture of what I did for my car...rather, how it USED to be
<IMG SRC="http://216.242.153.40/MembersList/UserPics/1126/intake01.jpg" border=0>
BIG PROBLEM THOUGH!!! Sure it screams at high RPMs...but there is an UGLY loss of low end torque. That is due to the extremely short length of the intake runner (from the filter to the throttle body). In order to generate that good low end power (rather, one of the things you need to do, there is more to it than that) is get some good air speed as it enters the throttle body. In order to do that...you need some length.
My half ass (but AMAZINGLY benificial!) fix to that was to get some good old black sewer pipe from Home Depot and hose clamp it between the throttle body and the filter. The effect was huge, and that was with a relatively short increase in length.
Needless to say there is much more work to be done...
But for those of you out there who want to put a cone filter straight on the throttle body...build a box around it...you are going to lose a LOT of low end torque...and run WAY lean too.
Just my $85.00 (I can't say $0.02 'cause I have spent way too much time and money on this thing! )
D. Neil Crawford
[This message has been edited by dcrawford (edited March 02, 2001).]
Reciprocity is offline   Reply With Quote
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 07-21-2002 09:05 PM
Should i block off the factory ram air intake after installing cold air? keystone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 12-07-2001 03:23 PM
Cold Air/Ram Air induction jersey judge Normally Aspirated Powertrain 15 10-29-2001 03:04 PM
Cold-air/Ram-air intake from hood vent (not scoop)? Fred Fredburger Normally Aspirated Powertrain 31 03-21-2001 11:13 AM
Custom Designs: Ram Air/Cold Air Intakes SoCalScooby General Forum Archive 10 05-31-2000 10:42 AM
