Old 05-02-2001, 06:53 PM   #1
kapnk
Member#: 4890
2001 Impreza RS
Post sweet n/a header
Very nice jdm ss header. costs about $1100 b4
shipping from japan. drool.
<IMG SRC="http://www.flatt-racing.com/media.html/imp-ex.html/photo3.jpg" border=0>
kapnk is offline   Reply With Quote
Old 05-02-2001, 07:07 PM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Those kinda look like equal length headers..can anyone confirm?
Keiho is offline   Reply With Quote
Old 05-02-2001, 07:14 PM   #3
kapnk
Member#: 4890
2001 Impreza RS
Post
i would say most definitely.
Old 05-02-2001, 07:16 PM   #4
Skylab
Member#: 4263
Question
Very nice. I wonder why Borla has to make the header off the passenger side make that big line across the front of the engine?
<IMG SRC="http://www.cobbtuning.com/images/borla-header2.jpg" border=0>
Skylab™
Skylab is offline   Reply With Quote
Old 05-02-2001, 07:16 PM   #5
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
which company makes that header?
GTBGUY is offline   Reply With Quote
Old 05-02-2001, 07:23 PM   #6
kapnk
Member#: 4890
2001 Impreza RS
Post
Old 05-02-2001, 07:29 PM   #7
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
sharp curves are much worse than length of pipe. That first header has an almost 180 degree bend in the passenger side pipe where it meets the cat.
I think you'd likely find you get equal, if not more, flow from the borla design than that one.
gavin is offline   Reply With Quote
Old 05-02-2001, 09:15 PM   #8
Bonzo
Member#: 2307
2009 530EXCXTZ1200
Orange
Post
primaries on both systems look kinda short to me, imo. Borla's collector is much more inexpensive to fab compared to the other ones. Not that their's anything wrong with that. Collector design along with exhaust design is not a science. Maybe easier to make is better for power. ? If I win the lottery tonite I will make an attempt to answer these questions
Bonzo is online now   Reply With Quote
Old 05-02-2001, 11:37 PM   #9
Buck-O
Guest
Member#:
Post
Hehe, if you only knew...
It jsut about takes a degree in geometry, physics, harmonics, and machining to make a perfectly tuned header, intake or exaust. There is alot of variable to it. Length, diameter, number of bends, back pressue. They all factor in. Its not such a big deal on a turbo car. But a N/A car is very VERY picky about tuning. And depending on how the engine is setup, there is a very fine line you can ride for your intake and exaust. Unfortunatly, there is no "perfect" solution for all around. There is an average setup...but we all know what that feels like.
So believe it or not. It is a science...a very big, complicated science.
Old 05-03-2001, 05:34 AM   #10
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post
It looks like the first header pictured is an equal length setup. You guys were talking about how bad it is to have sharp bends in the metal and how that restricts airflow.
Which would be worse? An unequal length setup with not to drasstic bends or an equal length setup that has one fairly drastic bend near where it hooks up to the exaust? I'm sure the engineer designed both of these setup with certain bends and other airflow restrictions to make sure the exhaust from both sides reaches the end of that header at the same time and at the same rate. Otherwise wouldn't it create backpressure?
[This message has been edited by MY99 2.5GT (edited May 03, 2001).]
MY99 2.5GT is offline   Reply With Quote
Old 05-03-2001, 06:41 AM   #11
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I would agree that the collector where the right hand bank joins in is so horribly designed that this header is not worth $1100 plus shipping. It also wouldn't surprise me if it performed worse than the Borla.
ColinL is offline   Reply With Quote
Old 05-03-2001, 11:18 AM   #12
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
The crux of the biscuit, as others have mentioned, is that that there is an almost endless supply of variables that affect intake and exhaust flow. There are general rules of things you should avoid, such as unequal lengths/sharp bends/drastically changing pipe diameters, etc., but even these can be worked around if you can't avoid them. Application specific trial and error is the overriding principle. This is why I cringe everytime somebody goes off about how easy it was for them to build their own intake/headers.
The only single inviolate rule is that nobody can tell you how a header is going to perform just by looking at it.
Old 05-03-2001, 11:22 AM   #13
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Oh, also, equal length doesn't necessarily matter. If you look at the borla design, the passenger side pipes join together almost immediately, while the collector on the drivers side is much further back. This would result in the exhaust on the passenger side flowing much quicker, and cancelling out the problem caused by uneven length. They have engineers design these for a reason .
Old 05-03-2001, 11:26 AM   #14
Bonzo
Member#: 2307
2009 530EXCXTZ1200
Orange
Post
I define science as being able to understand and predict in an area or subject. Exhaust design is far from being predictable or completely undertsood. It is still stuck in theory. No one really knows what is happening when you tune an exhaust. It is exhaustive engineered controled testing, experience and imagination. Having spent the last 11 years imersed in exhaust design, testing and fabrication for 2 and 4 stroke engines I have a feeling of what is out there. I also have some technology in tube forming and exhaust tuning to make the next step in gaining more power with exhaust. The area needed is to combine a complete package with intake tuning, valve timing combustion chamber, ignition and exhaust to raise the bmep of the 4s motor. It must be tuned as a complete system.
I welcome all thoughts on this. The more I learn about exhaust tuning the dumber I get
Old 05-03-2001, 01:42 PM   #15
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Post
borlas designed to meet CARB specs, which means they attach to stock cats, that's the #1 reason they are the way they are.
AO
m750 is offline   Reply With Quote
Old 05-03-2001, 03:33 PM   #16
deepbeep
Member#: 1392
Post
But does the Borla header actually have CARB certification?
deepbeep is offline   Reply With Quote
Old 05-03-2001, 05:59 PM   #17
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Question
I didn't know it needed one.
John2.5RS is offline   Reply With Quote
Old 05-03-2001, 06:16 PM   #18
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Post
Honestly I don't know if they do, but they're primary design factor is to maintain stock cats, otherwise... you'd be doing something very illegal & costly (possible 10k fine for removing your cats) Did I mention that I'm getting the MRT exhaust which does just that. Thought it's legal as my car is for track use only
AO
Old 05-03-2001, 08:15 PM   #19
Dre2932
Member#: 1211
93 Impreza L
Midnight BLK w/ GLD flake
Thumbs up
WOOW! Just what I'm looking for! There's just one thing, I don't have the money to pay for it. CRAP!
Dre2932 is offline   Reply With Quote
Old 05-04-2001, 05:26 AM   #20
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Post
Am I wrong, but isn't it by definition that a "header" is equal length to be called a header in the first place? The exhaust manifolds are what are not equal length and not classified as a header.
Mike
gaylemd is offline   Reply With Quote
Old 05-04-2001, 06:15 AM   #21
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Aaron, the MRT exhaust does have a cat, so although it is technically illegal, at least we won't be completely thumbing our nose at Mother Nature. Actually, now that I think of it, my car has over 50k miles on it and I'm pretty sure my cat is "broken" , so I think it needs to be replaces. Yeah, that it's!
Mike, a "header" just has individual pipes for each exhaust port, they aren't necessarily equal length. Of course, even a manifold has individual pipes for each port, but the pipes all dump into a common manifold as soon as possible. I guess that's how I would distinguish a header from a manifold - the manifold combines everything as soon as possible, while a header tries to give each cylinder room to breathe. (Very scientific, eh? ) Anyway, if you go here http://www.bassani.com/headers.htm you can see an example of an equal length and unequal length headers for a 5.0L Mustang. Those equal length headers may look like a twisted hornet's nest that couldn't possibly be efficient, but they actually do make a bit more power and torque on the dyno compared to the unequals. Not enough difference for me to justify the burned spark plug wires, the greater installation difficulty, etc, so I stuck with unequal length headers. Next up is some good equal length long tube headers, but that's not important right now.
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 05-04-2001, 11:43 AM   #22
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Post
oh, I know it has a cat, just not the stock one which is only semi illegal. What ever...
AO
Old 05-04-2001, 01:57 PM   #23
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
Post
I have no idea how most cars are designed in this respect, but it seems pretty dumb to me that the header pipes go into the cat at a 90 degree angle to the midpipe. If they went with the flow of the car (front to back), you wouldn't have the near 180-degree bend in the first header (and in our similarly-designed stock headers).
I know you can get aftermarket hi-flow cats, is that one of the things that is changed, or does the setup stay the same? Someone should manufacture a header/cat combination that fixes this problem.
Marc
edit: I just noticed that in the first picture the header has something on the right pipe. What is that? btw, I have the Borla ones on my car, and I'm very happy with them so far.
[This message has been edited by Marc Sawaya (edited May 04, 2001).]
Marc Sawaya is offline   Reply With Quote
Old 05-04-2001, 05:58 PM   #24
Bonzo
Member#: 2307
2009 530EXCXTZ1200
Orange
Post
that short piece is a flexible joint or coupler. It just allows some free play so the motor does not shake/vibrate the sytem apart. I many cases exhaust design simply comes down to "plumbing" challenges even if hi-perf systems. It's because of those darn fenders and stuff
Old 05-04-2001, 11:44 PM   #25
impRSa01
Member#: 4411
2001 Impreza 2.5 RS
Post
That thing on the secondary pipe is a flex joint. It is commonly used to make a pipe easily bolt up to something that otherwise could not without it. In this case, it is probably used to prevent cracking and to give the header a little play. I doubt it gives it too much play or they wouldnt be a leading header company in Japan. But that's what it is. It's only a flexjoint. It's not a cat or anything, and I doubt it's restrictive at all. Peace Out
impRSa01 is offline   Reply With Quote
FS : NY: Coated GTSpec UEL Headers/UP [Tial EWG]. Stromung Dual Tip CBE, Invidia DP, MORE! Get p00ted Engine/Power/Exhaust 19 07-30-2010 08:55 PM
AP Header, 850cc injectors, stock injectors, parts, etc nXgnSTi TXIC Private Classifieds 54 05-30-2010 04:48 PM
Borla Headers + Perrin Pulley = Sweet! DJHiRoller Legacy Forum 13 01-11-2007 06:11 PM
Sweet headers, I bet they make a bunch of power crash Off-Topic 22 08-04-2006 02:21 PM
sweet borla headers S.Damery Normally Aspirated Powertrain 16 04-10-2001 03:26 AM
