Old 01-28-2003, 04:00 PM   #1
spiralsmurf
Member#: 16085
2005 STi
Default my brake lights went out
alright the brake lights on my RS are not working at all. are there any fuses associated with the system? i've checked the bulbs and they are all fine. they only other element i can see if the microswitch connected to the brake pedal, but i dont know how this works exactly. has anyone had this problem? i need to get this fixed because i can't drive with no brake lights.
thanks,
dan
spiralsmurf is offline   Reply With Quote
Old 01-28-2003, 06:07 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
First thing I would check is all the fuses, or look in your owners manual and see what fuse is for the brake lights.
If the fuse is good I would check for power at the brake light switch, depress the brake pedel and make sure you are getting power out of the switch as well.
im guessing you are out of warranty?
jay
Old 01-28-2003, 07:41 PM   #3
spiralsmurf
Member#: 16085
2005 STi
yeah i'm out of warranty. i don't think the manual goes into detail as to fuses and such. also does anyone have the schematic for the brake light switch?
Old 01-29-2003, 12:34 AM   #4
Brady
Member#: 14838
2005 LGT--Garnet Red
197 Iggpoints
look at the manual again. it should indicate in there somewhere which fuse is for the brake lights, corner lights, etc. It's usually pretty easy to figure out which is which. it might even be as simple as looking at the fuse boxes - it might be readily identifiable there too.
Brady is offline   Reply With Quote
Old 01-29-2003, 02:24 AM   #5
spiralsmurf
Member#: 16085
2005 STi
problem fixed. it was a fuse.
All of my brake lights are out MF-DIF Electrical & Lighting 5 10-14-2008 12:24 AM
All my rear brake lights are out buccilli15 Electrical & Lighting 5 03-16-2008 02:16 PM
My Brake Lights are OUT! DragoonFly Newbies & FAQs 5 10-14-2007 11:20 PM
My dash lights went out while wiring my own radio...hlp? Subey03 Electrical & Lighting 0 09-22-2007 01:35 AM
Bork , my light went out.... Aaron'z 2.5RS Service & Maintenance 2 03-23-2007 03:22 PM
