Old 05-03-2001, 06:56 PM   #1
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Question Does having an air intake necessitate more frequent oil changes?
Thought I may have seen something about this before somewhere but can't recall if this is exactly what was said--in other words, that your oil gets dirtier faster with an air intake (Ganz to be exact).
subymamma is offline   Reply With Quote
Old 05-03-2001, 07:11 PM   #2
jlyttle
Member#: 2815
2004 Forester XT 5sp
Post
I would think that the Ganz would be the same if not better. After all, the air is drawn from the inner fender instead of from just after the grill under the hood. Anyone else have an opinion?
jlyttle is offline   Reply With Quote
Old 05-03-2001, 07:29 PM   #3
inpreza kid
Member#: 3334
Post
just done my 2nd oil change and switched to synthetic oil. i have a jc sports intake and i did notice that the oil was damm black when i changed it. not sure if it was from the intake but it was probably from me running the engine harder to hear the intake.
inpreza kid is offline   Reply With Quote
Old 05-03-2001, 09:43 PM   #4
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Post
I doubt it's the intake running the engine harder..it's your brain telling your foot to run the engine harder cause you're having so much more fun !!!
But also don't forget to do the ECU reset after the CAI mod.
-chrisC
silverSurfer is offline   Reply With Quote
Old 05-04-2001, 12:32 AM   #5
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
You will only have to change the oil more often if the intake you install has inferior filtration.
A fair amount of any contaminants that make it through the air filter will end up in your oil. This is the trade off you make with a free-flow filter. Most come from a racing design, which doesn't worry much about filtration because the engine is rebuilt well before it would become an issue. If you're running an aftermarket intake, or even filter, don't cheap out on your oil filter .
gavin is offline   Reply With Quote
Old 05-04-2001, 05:24 AM   #6
Buellboy
Member#: 3180
2002 Impreza WRX
Post
IMO, the oil is darker because of the rich condition created by the CAI, exhaust, etc.
I change my oil every 2000 - 2500 and it is usually fairly dark.
Buellboy is offline   Reply With Quote
Old 05-04-2001, 08:14 AM   #7
JJTheSubeDriver
Member#: 391
2004 STi Blue/Gold
2000 RS BRP
Post
I have a Ganzflow and my oil gets black about every 200-2500 miles. My filter is a K and N. I am thing of trying amsoil or a pipercross because they are foam and should maybe filter better but have a more restricted flow.
JJ
JJTheSubeDriver is offline   Reply With Quote
Old 05-04-2001, 08:34 AM   #8
bluesubie
Member#: 767
04 FXT
Post
The oil in my wife's OB with a K&N gets darker faster than my OBS with an Amsoil. And I drive harder, and make more frequent short trips. Both cars have drop-in panel filters.
Dennis
Old 05-04-2001, 10:04 AM   #9
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Post
Exactly, I willing to say the Amsoil filters dust better than any cotton filter. Also my intake tube has no dust like I have noticed with K&N.
Albert
Albert is offline   Reply With Quote
Old 05-04-2001, 11:08 AM   #10
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Your air filter doesn't have anything to do with your oil turning black. Oil turns black from the creation of carbon in the combustion chamber. Some of this will wind up in your oil, just like anything that slips past your air-filter. If your oil is coming out really black, then you're probably running really rich.
A smaller micron filtering oil-filter would remove much of the carbon, as well as other contaminants.
The crux of the biscuit is really your oil filter. If your oil filter is really good, anything that makes it into the engine is only going to cycle through once and not really do any damage.
Old 05-05-2001, 12:32 AM   #11
bluesubie
Member#: 767
04 FXT
Post
Gavin - I made a similar post a while ago here . Of course the opinions varied there as well. My wife and I use the same exact brand fuel, oil filter but different air filters.
I don't know if this is just their marketing hype, but Amsoil says that air filter quality does affect oil.
"...road dust and airborne grit drawn into the engine through the air intake ... these particles are carried by the oil into the clearances between bearings and other moving parts ... "
I'm no techie, but it does make sense in addition to the carbon.
Dennis
edit: I re-read your above post. I think you're saying dirt can get by the filter, it just doesn't necessarily affect the oil color.
[This message has been edited by bluesubie (edited May 05, 2001).]
Old 05-08-2001, 11:51 AM   #12
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Yes, exactly. Particles that get past your air filter will end up in your oil, but the oil turns black from the carbon generated during combustion, not from contamination.
What does the owner's manual say for distance between oil changes? mgoss79 Service & Maintenance 6 05-11-2008 11:25 PM
When is an air intake worth it? P-TownWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 01-11-2006 09:37 AM
Modifying hood scoop into an air intake? with FMIC STi-ll chillin' STi Forum Archive 15 08-27-2003 09:51 PM
How long does it take to switch out an air intake hose? Yasin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-19-2003 08:43 PM
Looking for an air intake for my'97 Legacy GT flavamost Legacy Forum 7 12-14-2001 08:25 PM
