#1 |
Member#: 4616
Vehicle:1999 2.5RS RBP |
Since October my driver side headllight bulb hasn't been lighting up very very dim and I just assumed the bulb was half dead or something. One of my friends saw it and told me that it probably wasn' the bulb and that it was most likely a melted harness. I got that checked at a dealership and they saw no visible electrical problems and said they required further diagnosis (I coudln't do it because i had to leave and get back to work). When I got home today I swapped driver side bulb with passenger and vice versa and here's what happens..
If both of the bulbs are in their original position then: driver = dim passenger = ok If I swap then: driver = dim passenger = dim If only one bulb is in on either side then it won't light up period. Now I've put the bulbs back to their original position and driver side doesn't light up at all now. I'm using PIAA H4 Superwhites. Thanks in advance.
#2 |
Member#: 31002
Vehicle:2002 WRX Blue |
dim lights suggest a bad ground some where. check to make sure the system is properly grounded.
#3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Check both bulbs carefully for a blown filament (there are two in each bulb) and also check your headlight fuses, there is a separate fuse for each side.
#4 |
Member#: 17193
Vehicle:1991 Legacy RS White |
Check fuses, check ground wiring....
#5 |
Member#: 4616
any online tutorials on how to check ground wiring? i don't really know anything about it
#6 |
Member#: 26303
Vehicle:2003 WRB GGA w/ 5MT I can see clearly now... |
Do you have a voltmeter (or can you borrow one)? If so, measure the voltage of all three headlight wires (on each side) relative to the battery negative terminal (attach the black probe to the battery negative, attach the other probe to the wire being measured) with the low beams on and then with high beams on. Also, measure the voltage across the battery. Report the results (all 13 voltage readings) back to this thread and we'll try and diagnose the problem.
#7 |
Member#: 31002
You can check the voltage but, it would probably read normal. Check the ohms. If the reading is too high that means there is too much resistance in the wire and that is where your problem is. Set the scale to 0-20. If you have more than 20 ohms resistance then you have major problems.
#8 | |
Member#: 26303
voltage lower than battery (+) on the hot side or voltage greater than battery (-) on the ground side is directly related to the resistance of the circuit. |
#9 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
sounds like a melted harness to me. the bulb sockets always melt. Check to see if the pins are loose inside the connector.
jeremy |
#10 | |
Member#: 31002
#11 |
Member#: 8555
..PopnGear, did you ever figure out if it was a melted harness? If so how did you fix?
Guys I have a huge problem as I have a melted drivers side harness and I think two of the positive wires touched cause now the bulb that the melted harness fits in is always dim! Is there something really messed up, or can I fix this issue pretty easily? Also if I order a HID kit can I solve this problem? PLEASE HELP!!!! cause I don't have a driver side light and can't drive the car at night.. Thanks Brian |
#12 | |
Member#: 3601
NWIC
Vehicle:2006 WRX Wagon BRIGHT BLUE! |
And you need to fix this, even if you go to a HID kit. |
#13 |
Member#: 8555
...So even though all of the bulbs that I have tried are dim in the drivers side, all I have to do is replace the harness and everything should be fine?
Thanks again ~B |
#14 |
Guest
Member#:
Oh this one is easy.. Replace the fuse for the dim side headlight located in the engine bay fuse compartment..
MO$ |
| Thread Tools | |
| Display Modes | |
| Strange rear light problem...help | MER | Electrical & Lighting | 5 | 04-09-2012 10:30 PM |
| tail light problems.....help! | 2.5rshead | Electrical & Lighting | 4 | 09-05-2008 11:46 AM |
| light problem, help | m1ek | Electrical & Lighting | 3 | 08-03-2006 05:42 PM |
| Brake light problem......help! | jobs | Electrical & Lighting | 1 | 06-26-2004 07:58 AM |
| Fog light problem...help | Scoobyslack1 | Interior & Exterior Modification | 4 | 07-27-2001 08:07 AM |
