Old 01-29-2003, 12:20 PM   #1
newbie sewbie
Member#: 10615
Default alternative to grounding mod
beside doing the grounding mod, what i found helpful was just using my dremel w/a sanding bit and going to all the existing ground points and removing the paint that the screw was sitting on......i'm sure some of you have done this already.....this can also be done in conjunction w/your grounding mod
newbie sewbie is offline   Reply With Quote
Old 01-29-2003, 09:40 PM   #2
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
more importantly though, have you felt a difference or measured a diffrence w/ a voltmeter or something?
Penguinking is offline   Reply With Quote
Old 01-30-2003, 09:53 AM   #3
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
After you do the sanding/grinding use some silicone gel or even vasoline over the area once you've reconnected. This will keep rust and oxidation from forming.
jack
Grounding Mod - Alternator Wine TheRedWRX Car Audio, Video & Security 5 11-26-2006 07:04 PM
Cheap alternative to RF mods and input jacks BrysImpreza Forester Forum 3 03-29-2004 09:25 PM
Single-point ground mod vs. Multi-point ground mods DrBoy01 Normally Aspirated Powertrain 5 12-05-2003 04:21 PM
Another rainy day...grounding mod how-to WRXagon South East Region Forum 14 07-07-2002 11:59 PM
Going to try that ground mod in a few minutes after work. rayder Southern California Impreza Club Forum -- SCIC 16 03-01-2002 09:14 PM
