Old 01-29-2003, 12:50 PM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Question A/F Gauge Electrical Interference?
My A/F gauge is kind of messed up and I can't figure out why.
after the car is nice and warmed up, it reads a bit on the rich side... thats fine... It's a Subaru
Then I turn on my lights... it reads Stoich, then I turn on the heat and the rear defroster... it's Stoich to Lean
Godforbid I turn on my fogs, then I'm totally lean!
What is causing this? Do I have an electrical bleed somewhere?
Should I shorten the power line?
Ideas?
Thanx!
Bry.
BrysImpreza is online now   Reply With Quote
Old 01-29-2003, 01:13 PM   #2
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
are you doing this during idle or this happens even while you're driving?
cRayZee is offline   Reply With Quote
Old 01-29-2003, 02:40 PM   #3
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
idle, when I'm driving, doesn't matter
Bry.
Old 01-29-2003, 02:54 PM   #4
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
But when you're driving, it reads the same as if all those things weren't on?
Old 01-29-2003, 02:56 PM   #5
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Correct, if I sit at idle its pretty much the same as driving with no electrical devices on.
Old 01-29-2003, 03:01 PM   #6
CyC
Member#: 23499
2006 Saabaru
Does it ever read A/F mixture as how you would expect? I mean... does it change at all when you hit the gas or let off or anything?
CyC is offline   Reply With Quote
Old 01-29-2003, 03:05 PM   #7
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
I think so, but it's not as sparatic like most other A/F readings I've seen, it's fairly constant
Bry.
Old 01-29-2003, 03:15 PM   #8
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
have you checked your battery voltage when you've turned on all those devices during idle? Would it be possible that the load affect the O2 sensor readings? Maybe the input voltage on the O2 sensor was reduced under heavy electrical load and outputs a lower voltage signal to the A/F gauge?
Installing a Greddy Oil Pressure Gauge Electrical btwrx06 Electrical & Lighting 0 12-18-2006 09:24 AM
Omori Gauges Electric Boost & EGT In Column Hayaboosted Private 'For Sale' Classifieds 4 12-20-2005 12:21 PM
Defi Gauge Electrical Problem??? brex16 Electrical & Lighting 8 10-18-2005 05:45 PM
Voltage fluctuations & Electrical Interference The Modaholic Engine Management & Tuning 4 06-16-2005 06:15 AM
Autometer Phantom Oil Press. Gauge - Electric drunkguy Private 'For Sale' Classifieds 1 09-30-2004 10:12 AM
