Old 05-18-2001, 08:53 PM   #1
urapnis
Member#: 3750
2005 Legacy GT
Atlantic Blue Pearl
Post Quick question RE: Intake Silencer Removal
THe instructions posted in the mods section..
Is that for all MY's?? I remember reading once that for MY 00-01, the location of the silencer was different from previous MY's.
Thanks
Dave
urapnis is offline   Reply With Quote
Old 05-18-2001, 08:59 PM   #2
grimlock
Member#: 2683
2011 STi 5-Door
Post
For 00 and 01, the silencer you're probably looking for is in the engine compartment, below the intake tubing and just aft of the ABS controller. That what you're looking for?
Ross N.
grimlock is offline   Reply With Quote
Old 05-18-2001, 09:03 PM   #3
urapnis
Member#: 3750
2005 Legacy GT
Atlantic Blue Pearl
Post
Ross:
I think so....I am very inept when it comes to anything mechnical, especially auto related. Yet I have an engineering degree...go figure...
Anyways, for anybody that did this mod on MY01, help please.
Dave
Old 05-18-2001, 09:06 PM   #4
Blindeye_03
Member#: 4418
2014 Golf GTI
Post
I have no idea where it is at...what kinda gains do you get out of the mod?
Blindeye_03 is offline   Reply With Quote
Old 05-18-2001, 09:11 PM   #5
urapnis
Member#: 3750
2005 Legacy GT
Atlantic Blue Pearl
Post
From what I have read, the gains, if any are minimal. But it makes the engine sound more agressive at WOT.
I just feel like doing something to my car. The only "mod" I have done was to put in PIAA super plasmas.
I'm just looking to perform some cheap mods that I may be able to perform myself.
I just ordered the Cobb intake a few days ago. Can't wait....
Dave
Old 05-18-2001, 09:47 PM   #6
Suba-RAW
Member#: 2831
Cool
This was one of my first mods. Real cool sound, at least better than stock.
The silencer is not in the fender like MY99 and back (not sure how far back). It's located just after the beginning of the intake starting behind the headlight and above the ABS controller. It's the big box-type can just behind the ABS. Undo the bolt holding the beginning of the intake, the one holding down the silencer, and the one on the part of the pipe pointing towards the engine before it snakes back left into the main air box. You should now be able to pull it up pretty good due to the flexible tubing near the engine. When high enough, just pull the silencer off, you may have to use some force, a little twisting. It will leave an open hole which could allow more engine heat in, but I didn't notice any loss, *maybe* a slight gain just in revs. You could block it off I guess. Cool sound, nothing like a real upgraded intake, but worth the trouble. I reset ECU, don't know if it was needed. Figured any change to the "normal" breathing made it necessary.
[This message has been edited by Suba-RAW (edited May 18, 2001).]
Suba-RAW is offline   Reply With Quote
Old 05-18-2001, 10:07 PM   #7
urapnis
Member#: 3750
2005 Legacy GT
Atlantic Blue Pearl
Post
Sube-Raw:
Thanks. Appreciate the response. Couple more questions:
I have ordered a Cobb intake. Will the silencer removal affect the intake installation in any way?
The "hole" you mentioned. Is it OK to leave it open? Will there be any potential problems with water, dirt, etc getting in? If I were to block it off, what should I use?
Thanks
Dave
Old 05-19-2001, 10:03 PM   #8
BRP1
Member#: 4358
01 Impreza
BRP
Post
The whole is goes into the cold air box so do not block it off! If you are worried about the hot air factor remove the vent shield on the passenger side(three nuts and two clips I believe) and this is just less stuff you will have to remove when you get your new intake.
BRP1 is offline   Reply With Quote
Old 05-19-2001, 11:21 PM   #9
Brainwalker
Member#: 2142
2000 Impreza 2.5 RS
Blue Ridge Pearl
Post
I removed the silencer and the whole mess of the stock intake when I put on my Weapon R intake. The sound is much better. I Actually feel (sounds) like i'm in a rally car..just not the same speed...haha.
The factory intake is mainly set up that way for the everyday person who wants a super quiet car. A bunch of plastick junk if you ask me.
Chris
Brainwalker is offline   Reply With Quote
Old 05-19-2001, 11:28 PM   #10
urapnis
Member#: 3750
2005 Legacy GT
Atlantic Blue Pearl
Post
Thank you everybody for your help.
I'm gonna perform this mod tomorrow. I guess I gotta go out and buy some tools now eh??
Dave
Old 05-20-2001, 11:21 AM   #11
Suba-RAW
Member#: 2831
Post
I forgot to mention K&N. If you're removing the silencer, the hole will allow more debris into the intake, especially with it pointed down towards the engine. K&N is definitely worth it.
As far as installing the COBB and this mod making it any different. If anything, this mod will make it easier to install the COBB, less stuff to move out. Also, when you remove the silencer, make sure you put the bolt back in that was holding the silencer down, it also holds down a support bracket for the ABS controller. Doesn't matter that there is a spacer on the top end of the bolt, just tighten it down and you're OK.
Old 05-20-2001, 03:17 PM   #12
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
http://www.remarcable.net/misc/legacy_outback/
I have the snorkusectomy instructions with pics up on my site.
I love it, it really helped with my hesitation problems and the sound is very nice.
It was free too.
remarcable is offline   Reply With Quote
quick question about intake silencer removal l2iceboy Newbies & FAQs 5 08-05-2008 03:44 PM
questions about intake silencer removal ASpec818 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-21-2003 09:54 PM
intake silencer removal question babymike Newbies & FAQs 20 11-05-2002 09:10 PM
Intake silencer removal question rsxblondie Tri-State Area Forum 20 03-15-2002 11:42 AM
Post Intake silencer removal questions bluey Newbies & FAQs 6 04-05-2001 10:12 PM
